6spd ???
Old Mar 30, 2009 | 05:42 PM
hot85vette's Avatar
hot85vette
Default 6spd ???
will lt1 bg 6spd or zf6 bolt up to an 85 witha 4+3 i want a manual but hate the 4+3
Old Mar 30, 2009 | 05:45 PM
Demonic85's Avatar
Demonic85
The ZF6 will bolt up no problem. Whats a bg 6 speed? The only one that I know of used in F-bodies was a T-56.
Old Mar 30, 2009 | 06:26 PM
LD85's Avatar
LD85
TKO 600 call Keisler
You can use the 4+3 BH and Hydraulics, Clutch FW etc.
Old Mar 31, 2009 | 05:50 PM
AKS Racing's Avatar
AKS Racing
The ZF6 bolts up to the ZF6 bellhousing no problem, but not to the 4+3 bellhousing.
Old Mar 31, 2009 | 11:07 PM
corvette1987coupe's Avatar
corvette1987coupe
I converted a '87 4+3 coupe to ZF 6-speed with all the parts that came out of a 1994 wreck. I used an article I am sure I have somewhere that tells how to do this conversion. I can FAX it to you when I located it. I think it was written by the ZF Doctor (see below) out west, maybe in Arizona.
E-mail billb@zfdoc.com or call Bill Boudreau at (602) 319-6575.
http://www.zfdoc.com/
http://grand-sport-replica-build.synthasite.com/
Old Apr 1, 2009 | 07:41 PM
jacksdad's Avatar
jacksdad
Default zf6 speed
i put a zf6 speed(new $1500) in my 86 4+3.i used my
original flywheel, new clutch,new bellhousing,new smaller
starter motor and some patience.just like everything
else after you do it you realize it was not that hard!
Good luck.
Old Apr 1, 2009 | 08:03 PM
LD85's Avatar
LD85
original flywheel, new clutch,new bell housing,new smaller
Good luck.
Did you use the stock ball pivot stud or the ZR1 stud?
Clutch disc was a sprung or unspring disc?
New clutch slave?
New Yoke ?
Cut the tunnel?
Speedo corrector for the 3.07 gear?
Not trying to be a but, just trying to relay all of the info to the OP
Old Apr 2, 2009 | 11:01 AM
AKS Racing's Avatar
AKS Racing
I did the ZF swap in my '87 replacing the 700R4. I have done several others, and though a bit of work, all seemed to be happy with the end result.
Though in retrospect, if I wanted a ZF, I would just buy a later model standard vette.
Aaron
To 6spd ???
