holley stealth ram help?
Old Mar 31, 2009 | 01:22 AM
mavidatt's Avatar
mavidatt
Default holley stealth ram help?
What all is needed to make the holley stealth ram work with engine. The Intake stealthram intake manifold and plenum are not to expensive. What else would be needed to make it work though? Could use parts from original engine so dont have to buy the complete kit, which is like $3000 and I definately aint paying that.
Old Mar 31, 2009 | 01:43 AM
rodj's Avatar
rodj
You only need the intake and fuel rail with AFPR $550 ;
http://store.summitracing.com/partde...5&autoview=sku
http://store.summitracing.com/partde...rt=HLY-534-186
Small cap dizzy/ coil and misc items , fittings , fuel line etc.
BUT ; it will not fit under a C4 hood without mods to the Plenum or a hoodscoop.
The $3K price tag is for the setup with aftermarket ECM which you don't ned
Old Mar 31, 2009 | 02:04 AM
BacknBlack's Avatar
BacknBlack
http://www.usmracer.com/L98_c_21175.html
Old Mar 31, 2009 | 07:13 PM
mavidatt's Avatar
mavidatt
thanks for the help
Old Mar 31, 2009 | 07:21 PM
mavidatt's Avatar
mavidatt
oh yeah would i have to get the computer chip modified to work with my engine?
Old Mar 31, 2009 | 07:37 PM
mavidatt's Avatar
mavidatt
oh yeah, you can buy a modified stealth ram that will fit under the hood, i had the link, it was more expensive though, with fuel rail kit and manifold it is $1100, i believe, which aint too too bad. Also the miniram intake with fuel rails from tpis is around $1200. Which one is better? Also would have to have modified chip for the miniram?
Old Mar 31, 2009 | 07:46 PM
rodj's Avatar
rodj
For what ?
What do you want to achieve? DD , street / strip , drag car
HSR is more "all round " intake.Better up top than TPI while still keepng good bottom end
MR is more "top end" intake; requires cam / gears / stall possibly to optimise
Both should have the ECM reprogrammed to maximise performance
Old Mar 31, 2009 | 07:56 PM
LD85's Avatar
LD85
Would love to see the link!
Old Mar 31, 2009 | 08:03 PM
mavidatt's Avatar
mavidatt
http://www.usmracer.com/Holley-Steal...on_p_2624.html
Old Mar 31, 2009 | 08:05 PM
mavidatt's Avatar
mavidatt
For what ?
A good street car that can still run pretty good, 350 hp or so. I would like to save money also as much as possible.
Old Apr 1, 2009 | 09:07 AM
Demonic85's Avatar
Demonic85
but they're screwing us over. Only $300 for the intake itself but if you want the one that bolts right in you have to pay $1100? Thats
Old Apr 1, 2009 | 09:41 AM
jmrl98's Avatar
jmrl98
Agreed, 1100 is kinda steep. But depending on your setup, and going by the hotrod(?) magazine link comparing intakes that has surfaced here, if it gives you 50 hp that's only around $22 per HP. Not that I always go the HP/$ route, but I'd pay that. Might be closer to $25/HP with a chip tune though...
Old Apr 1, 2009 | 10:08 AM
LD85's Avatar
LD85
How many hours do you thing it takes to make their HSR?
Old Apr 1, 2009 | 12:56 PM
BacknBlack's Avatar
BacknBlack
Isn't $350.00 of that $1100.00 for the fuel rails and adapters? So, labor costs $450.00.
Old Apr 1, 2009 | 02:14 PM
mavidatt's Avatar
mavidatt
well paying $1100 for the one that bolts right in and fits under the hood then having to pay $1500 for a high rise hood along with the cost of the stealthram.
Old Apr 1, 2009 | 07:08 PM
rodj's Avatar
rodj
Work involved
http://www.joby.se/corvette/mods/2005-10-03_hsr/
Old Apr 1, 2009 | 08:48 PM
LD85's Avatar
LD85
I call this "the easy way"
see sig for "Hard Way"
Old Apr 1, 2009 | 10:58 PM
Demonic85's Avatar
Demonic85
I like the easy way, looks cheaper to do. I do have another question, why wont the stock fuel rails work, too wide?
To holley stealth ram help?
