Lug nut replacement
Old Apr 1, 2009 | 12:30 PM
conv90's Avatar
conv90
Default Lug nut replacement
I think I need to change /replace the lug nuts expecially on the rear wheels.
Is there some replacement part number to search?
I'm looking to see a replacement part number on Summit catalog.
-Beppe.
Old Apr 1, 2009 | 12:33 PM
Square's Avatar
Square
I bought 5 lug nuts for my 86' from Advance Auto parts. I think they were about $1 each. They have worked just fine so far (they have been on the car a couple of years).
Old Apr 1, 2009 | 12:36 PM
StealthLT4's Avatar
StealthLT4
The ones at Advance Auto will work just fine. Be sure to torque to 100 ft-lbs.
Old Apr 1, 2009 | 12:39 PM
conv90's Avatar
conv90
I'm In Italy...
Are these nuts with the external thread to put on the plastic cover?
-Beppe-
Old Apr 1, 2009 | 12:57 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Yes. Advance has both. Ones with external threads and ones without.
Old Apr 1, 2009 | 01:40 PM
Elephanthead's Avatar
Elephanthead
Unfortunately I don't think Italy has advance auto part stores.
Old Apr 1, 2009 | 05:37 PM
c4cruiser's Avatar
c4cruiser
Actually there are a number of GM cars that use the same lug nut with a plastic cap. Cavaliers, some Camaro's, and even Pontiacs, and Buicks use them. The part number should be the same for any of them.
If you can't find the stock GM lugnuts then you could use any lug nut that has the same thread pitch and diameter as the Corvette wheel stud. But the new nuts will have to have a 60 degree taper for them to fit the hole in the wheel. Again with just regular lug nuts, most any fairly new GM passenger car will use the same size lug nut and will most likely have the same taper.
Is there any type of GM dealership in Milan? I would think there would be one in Rome but that's a fair distance to drive Maybe Munich?? Some of the Corvette accesory catalogs will do international shipments, but it cost a bunch by the time you add freight and duty/customs taxes.
Old Apr 2, 2009 | 06:20 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
GM part number #10028615
Old Apr 2, 2009 | 08:05 AM
Dudeurgettnavette's Avatar
Dudeurgettnavette
order from rockauto.com I'm sure they ship international
Old Apr 2, 2009 | 09:08 AM
conv90's Avatar
conv90
Thanks to all!
Old Apr 2, 2009 | 02:53 PM
jsinga's Avatar
jsinga
Not a bad idea for everyone with C4 to take a look at their lug nuts. When I got looking at mine years ago they scared me. They had hardly any threads left in them. Cheap insurance under $25.
JS
To Lug nut replacement
