my 1989 won't start
Old Apr 1, 2009 | 06:42 PM
rbohrer318's Avatar
rbohrer318
Default my 1989 won't start
My '89 has been running great for a while. I drove it today, parked it, when I got back in the car it started right up. When I put it in reverse the car just killed. Now it won't start at all. The motor turns over but nothing else happens; not even a sputter. Any ideas? Thanks in advance
Old Apr 1, 2009 | 06:46 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
check the fuel pump, if thats ok try the ign control, module, rotor in the dist could have broke also.
Old Apr 1, 2009 | 07:59 PM
jfb's Avatar
jfb
Go home and get your timing light, fuel pressure gauge, and a noid light. While cranking check for spark and timing. Next, put the fuel pressure gauge on the shrader valve on the end of the right fuel rail and see if you have 35-42 psi and see if it holds up with the ignition off. Unplug an injector and connect the noid light and see if it pulses during cranking. Engines need spark, fuel, and air to start and run. You are missing one or more.
Old Apr 1, 2009 | 09:28 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default jfb
I used to know what a noid light is. Now I have forgotten. ?
Thanks,
Corvette Mike
Old Apr 1, 2009 | 09:39 PM
Crzyfrlss1's Avatar
Crzyfrlss1
Thanks,
Corvette Mike
Take a look here. I got the complete set for $60 a few years ago.
They work great.
http://buy1.snapon.com/catalog/tools...e=snapon-store
Old Apr 1, 2009 | 09:49 PM
CorvetteMike2024
Corvette Enthusiast
Default noid
Im still confused. How and what do you do with it? Sorry for stupid question. Once you tell me it will come back. I recall a few years ago thinking about getting one.
Old Apr 1, 2009 | 09:58 PM
Crzyfrlss1's Avatar
Crzyfrlss1
The noid light plugs into the fuel injector harness plugs.
Just unplug injector of your choice, insert proper noid light, crank car over.
If the light flashes the computer is telling the injector to fire and that driver circuit is working correctly.
If it doesn't...well you got problems.
Best to check the basics, I say check for spark and fuel pressure first.
Old Apr 1, 2009 | 10:01 PM
Crzyfrlss1's Avatar
Crzyfrlss1
One more note.
DO NOT use a test light to try checking for injector pulse.
The injector driver circuit from the ECM will almost certainly get fried.
The noid lights have the proper resistance built in so this doesn't happen.
Good luck.
Old Apr 1, 2009 | 10:18 PM
CorvetteMike2024
Corvette Enthusiast
Default noid
Ah yes, its all comming back. Back when I was having injector issues in 2005.
Thank you.
Old Apr 1, 2009 | 10:22 PM
Crzyfrlss1's Avatar
Crzyfrlss1
Thank you.
You're welcome.
Now hopefully the OP has enough info here to get his no-start issues sorted out.
Old Apr 2, 2009 | 12:29 AM
Sweet 90's Avatar
Sweet 90
Thanks,
Corvette Mike
At our age Mike, maybe you were thinking of a "roid" light
Jim
To my 1989 won't start
