PS rack, (flush)
Old Apr 1, 2009 | 07:54 PM
Jim D's Avatar
Jim D
Default PS rack, (flush)
I have an 87, and the ps fluid is milky. I have a pump and reservoir ,and hoses. How can I flush out the ps rack, thanks Jim.
Old Apr 1, 2009 | 10:09 PM
bills1985corvette's Avatar
bills1985corvette
Jack up the front end. Remove all the fluid you can from the canister. remove the upper hose on the canister (return hose) and put an extension of clear plastic hose on the removed line and run it into a collector bottle. Fill the power steering canister with clean fluid. Get in the car and turn the wheel full left and then full right keeping doing so till you see clean fluid running out the return hose extention into the bottle. KEEP CHECKING THE POWER STEERING CANISTER TO KEEP FULL DO NOT ALLOW IT TO RUN DRY CHECK OFTEN WHILE TURNING THE WHEEL. Easy job ... good luck.
