What tranny do I have?
Old Jan 30, 2002 | 10:42 AM
IcemanZ06's Avatar
IcemanZ06
Default What tranny do I have?
The car is a 1993 Automatic. Build number 3,455. What model transmission do I have?
( I would look under the bumper to see but the car is in Arizona and Im in Virginia)
Old Jan 30, 2002 | 01:41 PM
vader86's Avatar
vader86
Default Re: What tranny do I have? (IcemanZ06)
isnt it the 4L60E? i thought the changeover was in 92
Old Jan 30, 2002 | 02:39 PM
GlockLT4's Avatar
GlockLT4
Default Re: What tranny do I have? (vader86)
eehhh ... I can't remember, but my '94 has it.
Old Jan 30, 2002 | 02:41 PM
Timmy!'s Avatar
Timmy!
Default Re: What tranny do I have? (Glock'94)
Should be the 4L60E
Old Jan 30, 2002 | 03:09 PM
dgoodhue's Avatar
dgoodhue
The change over was during the 93 production run. I would since you have a low number that it doesn't have the "E" as I thought i read it that it happen late 93, but I am not 100% positive.
Old Jan 30, 2002 | 06:17 PM
David-F's Avatar
David-F
You have a 4L60 in other words you have a 700R4 you do not have an electric shift trans the vett didn't go to the 4L60E untill 94 with the change to a PCM instead of a ECM (PCM powertrain control module, ECM engine control module. The re were no 93 4L60E cars built there were some trucks but the Vette did not get it untill 94, the 93 ECM is unable to control engine and trans and there is only one ECM used on a 93. If you want to know for sure only a 4L60(700R4) use a TV cable, so if you have a cable that goes from the ABS throttle pull off motor over the left valve cover and down to the trans that is the proof that you have a 4L60(700R4)
David Fulcher
Old Jan 30, 2002 | 07:08 PM
vader86's Avatar
vader86
Default Re: What tranny do I have? (David-F)
That sounds about right, 4L60. I knew that the early models of one year had 4L60 and the late models had 4L60E
Old Jan 30, 2002 | 08:23 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Glad we settled that! :D
Old Jan 30, 2002 | 09:18 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Are we sure :D
Old Jan 30, 2002 | 09:37 PM
93 ragtop's Avatar
93 ragtop
Default Re: What tranny do I have? (mackeyred96)
Are we sure :D
Im for sure I wish I had the E version. Sure seems to be more percise on WOT shifts.
To What tranny do I have?
