Does this Exhaust Hanger have rubber insert
Old Apr 2, 2009 | 02:34 AM
Stingraynut's Avatar
Stingraynut
Default Does this Exhaust Hanger have rubber insert
I noticed that the exhaust hanger near the gearbox seemed to be loose in the part it hangs from, and I suspect it should be set in rubber.
Here's a picture with red line pointing to the part and the relevant part number pasted in above -
Does anyone know if it should have rubber or not?
Old Apr 2, 2009 | 02:36 AM
Demonic85's Avatar
Demonic85
Is that for a LT1 car? I know my '85 didnt have rubber bushings on the cat hanger, only the muffler ones.
Old Apr 2, 2009 | 03:19 AM
rodj's Avatar
rodj
Maybe it fell out
Old Apr 2, 2009 | 03:30 AM
Stingraynut
G'Day Rod - thats the one- so there should be rubber in there - thats great to know. Should be easy to get some more rubber and refit - how heat resistant should it be???
Old Apr 2, 2009 | 03:54 AM
rodj's Avatar
rodj
Rob
needs to be pretty good , everything up in the tunnel gets fairly warm
Old Apr 2, 2009 | 08:19 AM
Stingraynut
Ok, not sure what I'll use, maybe I can get some silicon ? any suggestions?
At least I know now where the vibration is coming from on acceleration!
Old Apr 2, 2009 | 09:49 PM
NMsharkracer's Avatar
NMsharkracer
From: Formerly from the Great White North but now residing in the Desert Southwest NM (The Land of Dis-Enchantment?)
Just bought one for my '92. It's a metal bracket that bolts to the DS of the trans and has two springs with attachment plates that hang done from the sides. There are no rubber parts and it is NOT a rigid mount.
Old Apr 2, 2009 | 10:09 PM
Stingraynut
Springs - thats an idea - must be different on the 88 because rodj's pic clearly showed rubber - thanks for the info
Old Apr 2, 2009 | 10:51 PM
LT1 Spirit's Avatar
LT1 Spirit
I used coolant hose to stop the knock between the frame and pipes of cars Ive had before. But that was close to the back of the car.
Old Apr 3, 2009 | 07:33 AM
rons85's Avatar
rons85
Does anyone know where you can Buy that hangar. I'd settle for Either design - the rubber isolater (early design?) or the dual spring one. That (on my '85, Rubber) hanger is not available Anyplace I've looked, and hasn't been for several years now. I've lived without it for nearly as long as I've Had this car, coming up on nine years now
Old Apr 3, 2009 | 11:50 AM
Itshakes's Avatar
Itshakes
Default Muffler hanger insulator w/bracket
Corvette Central has 'em---Part # 324441--'84-'96 Muffler hanger insulator w/bracket--$9.95 ea.
Make sure this is the part you need. Their #800-345-4122
Old Apr 3, 2009 | 12:26 PM
rons85's Avatar
rons85
Corvette Central pn#324441 is the hanger/isolator at the back, behind the mufflers (one on each side). It is NOT the central hanger off the transmission tailshaft that we are talking about here.
Still looking..
To Does this Exhaust Hanger have rubber insert
