Lowered - correcting bump steer?
Old Apr 3, 2009 | 03:13 PM
Aardwolf's Avatar
Aardwolf
Default Lowered - correcting bump steer?
Now that my car is fully lowered, what have others done for correcting bump steer? I see Exotic Muscle sells a kit, anyone used it? From memory of other cars I think the rear toe rod gets shimmed up around 5/8" and the front down? Any good home made ideas for checking?
Old Apr 3, 2009 | 05:38 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Fully lowered?
It depends on how much you lower it.
You need to measure your bump steer
EDIT
Here's how to measure it
http://stockcarproducts.com/tech1n.htm
Old Apr 3, 2009 | 05:47 PM
Aardwolf's Avatar
Aardwolf
I'm thinking about copying what others have done till I can get something like that. Or find a shop that has one. Craig Brian Johnson posted about .665" shim in the rear. Do you just put shim on top of the spindle?
Old Apr 4, 2009 | 01:35 PM
BrianCunningham
I haven't lowered mine.
I'm going to adjustable a-arms so I can get the camber I want.
Old Apr 6, 2009 | 02:32 PM
Aardwolf's Avatar
Aardwolf
I've been talking with CJ on what he did. His car was so lowered the frame was notched for clearance. So .665" would not be accurate for mine.
He drilled out the spindle for a straight bolt, as you can't shim and have the tapered bolt slopping around in there. So a ball joint that has a straight bolt would be needed.
I'm surprised more people aren't doing this mod. It's especially important for those members that bought the DRM rear relocating brackets. As those let the car squat more, further going toe out. Maybe they run 1/4" toe in?
I'm going to try 1/8" toe in for now and replace the ball joints later. I know I need front ones as well and the tie rod was ready for replacement.
Edit, Banski and VBP rear toe rods come with an insert to use in the knuckle.
To Lowered - correcting bump steer?
