96 lt4 manual trans removal
drop the exhaust
pull the c-beam and drive shaft
remove the shift **** and put trans in 3rd
drop the trans
drop the cats
remove the clutch fork pivot retaining nut and unscrew the clutch fork pivot (fork pivot probably not the right name, but it is what it is)
pull the bellhousing (if the clutch fork pivot is not loosened then removing the bellhousing is possible, but verrrrrry difficult)
take out the pressure plate and clutch disk, from this point you can remove the throw-out bearing and reassemble in reverse.
Kind of a PITA.
good luck
EDIT: nevermind, theyre calling for rain on Mon/Tues and Thurs/Fri... doubt i could get it all finished in only a day. maybe if i didnt have to work... oh well. theres always next week
The tranny is surpisingly heavy, have a jack ready for it, and you may need a buddy there to help put it back in.
Highly recommend for you to by the field service manual "FSM"
Disconnect the battery
Before you start jacking the Vette up, remove the center console, the shifter **** and all bolts that hold the shifter boot.
I used 4 ton jack stands, Use 6 ton jackstands. 6 tons will give you a higher clearance for the tranny to go back in. The take out/off is easy because you can always drag it out.
Follow instructions from the FSM or ZF Doc
This is a good time to replace all U-joints, engine's rear main seal, to consider a short shifter (B&M or Hurst), tranny oil change (castrol TWS) and rear axle oil change.
The C-beam was not as difficult, be careful with the fuel shut off sensor near the firewall when you lower the tranny to remove the C-Beam.
You can do this yourself as long you got a jack and an extra jackstand (to hold the engine on place) BUT, an extra set of hands will make things easier.
Okay questions. Where is the best place to buy a stock clutch kit? Hurst or B&M shifter(which is better?) and the trans is leaking from the tail shaft area, where to buy seals and maybe gasket for tail shaft? Also U-joints. Maybe a vendor that carries all of these parts. Thanks guys!
Is teh rear tranny seal leaking all the time, or just while the driveshaft is out? it's normal while the shaft is out. Good time to change the fluid anyway. 17mm Allen.
Shouldn't have to remove the cats. The hard part though then is getting the starter out of the way -- last time I found that a 13mm u-joint socket (Craftsman) worked really wll for this. Not enough space to get a regular socket+u-joint in there. Need the combo that's a little shallow socket with integrate u-joint to sneak in there beside the cat and get the starter bolt.
Getting the @#$@#$ tranny back onto the jack while under the car can be fun. I always resort to using some pieces of 2x4 or simailar and building it up on each end piece by piece until I can get the Big floor jack under there. Again, having a helper to move the jack up and down can be nice.
When re-installing, the wiring harnesses up top can get trapped by the housing -- having someone up there checking for that (from the passenger side) can help. Get new PP (and FW if you remove it) bolts from the Stealership. I believe they're one-time use, and cheap insurance. Make sure all the grounds that attach to the top-left BH bolt get re-attached. If not, you'll find "things" that just don't work (like say, cruise control).
I had (and needed) a hand to get the transmission out. Putting it back was much easier. I actually did it by myself as I was not patient enough to wait for help.
I did this:
I did the same thing to get the trans up, real jack under the drain plug (pretty well balanced) and a bottle jack on top of a cinder block under the tail shaft so I could let it rest hands free.
As for the seal, I got it from Autozone. They had it in stock. The # they look up in the book or computer is wrong, but if you bring in the old seal the part number from the seal will help them find one that is commonly stocked.
I gave up looking for U-joints because I could not find a spicer distributor. I went with AZ ones because they carry a warranty. They are made in china and will probably come back to bite me.
