1993 Emission/PCV valve question
Old Apr 5, 2009 | 09:36 PM
sthamby's Avatar
sthamby
Default 1993 Emission/PCV valve question
I just purchased a 1993 Corvette. I went to replace the pcv valve and unhooked it from passenger side valve cover. What I thought was the pcv valve turned out to be just a plastic elbow. I couldn't find a place that the valve might be on the other side of the engine. Would there be any reason someone would replace the valve with just an elbow or am I looking in the wrong place? There is also 2 small brass tubes coming out at an angle from the left and right front sides of the intake manifold. Niether are connected to anything but both look as if they had been at one time. I have to take the car to get it tested for emissions before I register it and I'm worried it might not pass if something is missing. Any help would be greatly appreciated.
http://picasaweb.google.com/scott.ha...84010077046258
http://picasaweb.google.com/scott.ha...84016361370690
http://picasaweb.google.com/scott.ha...84030538576546
Old Apr 5, 2009 | 10:36 PM
BobRR3's Avatar
BobRR3
The PVc valve in on the Drivers side. About halfway bach on the intake plenum
Old Apr 6, 2009 | 07:44 AM
sthamby's Avatar
sthamby
Thanks. Do you have any idea what the 2 brass tubes might be?
Old Apr 6, 2009 | 09:15 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Brass tubes - someone has done a throttle body bypass for the cooling system.
If you don't have any water leaks its OK to leave it alone.
For the PCV valve look for a very short rubber hose that seems to loop between the upper portion of the intake and the lower on the driver side.
Old Apr 6, 2009 | 12:23 PM
sthamby's Avatar
sthamby
Thanks for the help!
Old Apr 6, 2009 | 12:46 PM
jimg's'93's Avatar
jimg's'93
I went and bought a cheap pack of large vacuum caps at the Zone to place on those tubes left by the tb bypass mod. Just looks better IMO.
Old Apr 6, 2009 | 11:50 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
if you do try and remove the PCV valve, be very careful as the small rubber hose (at least on our 94) is likely to be brittle a will break.
If it does, you'll need to go to the dealer to order a new one.
Old Apr 7, 2009 | 07:35 AM
sthamby's Avatar
sthamby
You're right. I looked at it and it does seem to be hard and brittle.
Thanks for the advice
To 1993 Emission/PCV valve question
