Throttle position Sensor
Old Apr 6, 2009 | 03:59 PM
ArmyBoyATC's Avatar
ArmyBoyATC
Default Throttle position Sensor
I need to know what to set my T.P.S to on my 1985 corvette. Thanks
Old Apr 6, 2009 | 04:11 PM
Muffin's Avatar
Muffin
.54 volts closed.
Old Apr 6, 2009 | 04:34 PM
nutz4c4's Avatar
nutz4c4
Originally Posted by Muffin
.54 volts closed.
Old Apr 6, 2009 | 10:28 PM
John A. Marker's Avatar
John A. Marker
Standard TPS setting is .54 volts with key on (car not running) and 4.49 volts with accelerator pedal fully to the floor (WOT). You have to play with the setting a little to get both idle and WOT setting.
So of us that run modified engines have discovered that a idle setting of around .60 get us off the line a little faster with better response.
To Throttle position Sensor
