Roller Lifters?
Old Apr 7, 2009 | 12:28 AM
72MiuraSV's Avatar
72MiuraSV
Default Roller Lifters?
I read on a C4 information site that all 87 and up c4s came standered with roller lifters. Is this true?
Old Apr 7, 2009 | 01:09 AM
Calderone's Avatar
Calderone
yes its true
Old Apr 7, 2009 | 08:43 AM
JeepCycle's Avatar
JeepCycle
Originally Posted by Calderone
yes its true
Do you know if one of these stock setups will fit in a stock L98 from 1985?
Old Apr 7, 2009 | 08:46 AM
Calderone's Avatar
Calderone
as far as i know the block is different,for the lifters but i think someone can chime in
i think there must be a way to retrofit them
Old Apr 7, 2009 | 09:09 AM
floridamale's Avatar
floridamale
I believe the only difference in the motor's are the roller lifters & aluminum heads.
Old Apr 7, 2009 | 09:12 AM
Calderone's Avatar
Calderone
yes i think that too
but from what i know the block is a roller block in 87 and up.-
he needs to make his 85 a roller ,but im not sure if he can do that
but im sure there must be something.-
Old Apr 7, 2009 | 09:45 AM
Muffin's Avatar
Muffin
The 85 block will not accept an OEM roller cam. Two reasons:First flat tappet cam lifters are ground to keep the cam pushed toward the rear of the block. Roller has a cam retainer plate that does this. Nose of a roller cam is stepped to fit the plate. Second the roller lifters are held in position by retainers and a hold down piece called a spider.Keeps them from rotating as the cam turns. Several cam companies make a retro-fit cam/lifter kits for non roller blocks but they are very pricey.
Old Apr 7, 2009 | 09:48 AM
Calderone's Avatar
Calderone
that's what i was thinkin about !
Old Apr 8, 2009 | 03:27 PM
JeepCycle's Avatar
JeepCycle
Thank you for that info...sigh...one of these days...it's looking more and more like the easiest way to go is an engine swap for a build up...I was hoping to be able to do things reasonably priced on step at a time...
To Roller Lifters?
