Eprom burning for 1989
Looks pretty cute if it works.
After about ten minutes worth of reading, it looks like I can finally tune my '89. Or am I really wrong?
Anyone have advice before I begin this learning curve?
I have down loaded Tuner Pro RT from Mark Mansur and think I am at the starting point?
TJM
Start here
http://www.thirdgen.org/techboard/di...uide-book.html
This is for LT1's but basic tuning theory the same
http://para.noid.org/~lj/PCM%20Tutorial/PCMtutorial.htm
http://para.noid.org/~lj/PCM%20Tutorial/Definitions.htm
3rd Gen Prom site
http://www.thirdgen.org/techboard/diy-prom/
has the most activity and you will get answers so long that you have read the link above and not ask something already covered there.
Basically you datalog your engine to see what it is doing and then do small changes and datalog the effects.
Somethings are obvious and don't need to be logged like fan ON/OFF temps , injector size , idle speed ,etc.
Then you get into the heavy stuff; can change spark advance , amount of fuel
Start here
Sounds as if the Equipment is OK and Moates is a knowledgeable guy.
Maybe I am expecting to much from this, but I expect to be able to optimize spark and fuel : throttle issues. Tuning was half the battle pre 1982... ?
It absolutely amazes me how little traffic I see on tweaking the computer after modifications?
I hear endless talk in the TECH section about the minutia of detail about stuff I forgot in 1972? Cams, Hp, Rockers, HP, pistons.Hp . and nobody seems to tune the cars, expecting the computer to just "Do IT"
You guys let me know if I am off base, but you modify the older C4 motor, you pretty much need to Re tune the Chip?
Yes?
TJM
I learned to read the instructions before burning. Have fun!!
However by datalogging you can see areas where you can "tweak" to optimise perf or economy
There are some seriously heavy tuners / hackers on GM ECM's over on 3rd Gen.
Remember none of this is from the factory.People have got in and dis-assembled the factory code and written programs to tune
Most C4 guys don't seem to get in that deep ; just send out to one of the proven tuners for a tune. Understandable when you see what you can get into with home tune; steep learning curve.
As a note ;I installed a ZZ4 cam in my '89 with ported intake.Ran excellent on stock tune.
However once I got into dataloging ,I found the spark advance WOT mid range was too much , minor knock counts and the ECM was momentary taking spark out to prevent knock.
You could not feel this SOTP , but you could see it in the logs
Well I am sliding down that curve. Day three into the reading.
Time to break something!! Going to try and copy my stock Binary programing fair test run?
I have bumped into a theory that a wide range O2 sensor will help improve Air/fuel ratio. Actually it is pretty much essential if you wish to do so. At least that's how I read it.
$70 dollar part?? I'll have to give it some thought, unless someone actually knows?
TJM
http://www.moates.net/fileman/index....B%206E%2094/6E
If using Tunerpro need 6E xdf from here
http://www.moates.net/fileman/index....neral%20Motors
Need to log in
matesuser
moatespassword
Interesting to compare auto v manual calibrations
I believe for $70 all you will get is a heated O2 sensor.
Ulimately need a standalone WB like the Innovate LC-1 orLM-1
http://www.innovatemotorsports.com/products/lc1.php
http://www.innovatemotorsports.com/products/lm1.php
