Loose steering column
Old Apr 7, 2009 | 04:09 PM
Allieboy's Avatar
Allieboy
Default Loose steering column
I am at work so i cannot do a search so i had to have my wife post this.
My car is at the mechanic now. I read 1 time that if the pins are loose you can replace them with larger pins. Can you please tell me where to get the larger pins.
thanks
Old Apr 7, 2009 | 05:42 PM
jakers's Avatar
jakers
St. Jude Donor '06
Here ya go.
http://www.zr1specialist.com/
Brace yourself. Mark wants $55.00 for the pin.
Old Apr 8, 2009 | 01:28 PM
josephf31's Avatar
josephf31
Default I
Originally Posted by jakers
Here ya go.
didn't see any pins on that site, what section are they in?
and is that $55 for ONE pin? (need 2 of course)
Joe
Old Apr 8, 2009 | 02:01 PM
jakers's Avatar
jakers
St. Jude Donor '06
Joe
The pin is not shown on the site. I called Mark a few months ago and discussed with him. Almost ordered one. I flinched at the $55.00 price. A few forums members have installed Mark's pin and from the sound of previous posts the pin appears to work as advertised. I cannot vouch for them personally. I do know that Mark sells one pin to fix this issue. I recommend that you call Mark directly and discuss. Good luck.
Old Apr 8, 2009 | 03:36 PM
pologreen1's Avatar
pologreen1
do a google, because the search is down right now. There are a couple threads here about it, and one guy just used JB weld for a cheap quick fix, I guess it worked.
Old Apr 9, 2009 | 09:48 AM
josephf31's Avatar
josephf31
Default Thanks
Guys. I already did the JB Weld thing last year, and so far it seems to be holding up OK. Can't complain since the only cost was about $5 for the JB Weld and my time.
The column still has some play in it, and I'm a little leery of putting my weight on the wheel (since that is what wears the thing down in the first place), so a fix with new pins, rather than the other option of replacing the entire column/housing sounded good.
To Loose steering column
