Any tips on removing/installing engine?
Old Apr 8, 2009 | 01:18 AM
89Corvette6spdFX3's Avatar
89Corvette6spdFX3
Default Any tips on removing/installing engine?
I'm getting ready to remove and replace my L98 with a ZZ4 this Saturday. Other than having all the proper tools and service manual, are there any other tips you might share? Any pictures of your own project? Any snags you ran into when doing your own?
Anything would be appreciated as I need to be as familiar as possible before I jump in. Thanks!
Old Apr 8, 2009 | 02:38 AM
rodj's Avatar
rodj
Remove dist
Remove wiper motor as plastic cover often get hits as engine comes out
Taking it out with bellhousing or not?
If leaving bellhousing
Easiest to disconnect C beam from trans , place jack under trans and lower until engine hits firewall.This allows you to get at the top bellhousing bolts over the top of the trans with long extention ( 9/16)
A/c compressor can be unbolted and hung over side of car on the hoses to save having to regas
Old Apr 8, 2009 | 03:04 AM
Firevette's Avatar
Firevette
Cruise-In X Veteran
Watch the placement of your jackstands if removing the engine from the side. (aka with the hood on) Allow enough room for the legs of your engine hoist to get in there.
Old Apr 8, 2009 | 03:13 AM
jdraughn's Avatar
jdraughn
I just about have my engine removed, I worked on it for a couple of hours yesterday. I was able to get the bell housing bolts from above with a 14mm wrench. The flex plate were 15mm which I also used a wrench. I had to shove a large 18mm or so wrench between the torque converter and transmission to stop the engine from turning, and I used a second wrench piggy backed on the 15mm to get enough leverage to break the bolts loose. I also used a good size wrench in the big holes in the flex plate to turn the engine so I could get to the next bolt.
My question is about the mounts. they are about the only major obstacle left. After that it's just double checking for misc wires and hoses. There are two bolts that are easy to get too from above/outside standing in the wheel well. There is a large bolt running through the middle of the motor mount and if I reach back and feel of the back of the motor mount I think I can feel a third small bolt like the two on the outside. Are those 3 bolts the right ones to remove? The two facing out and the one on the inside? Or should I just try to remove that one huge bolt running through the middle of the mount? Or is there a different way?
Old Apr 8, 2009 | 06:10 AM
Movnviolation's Avatar
Movnviolation
I have had my motor out of my 89 twice now. It is really quite easy. Leave the bell housing on the motor. I also pulled the pulley off of the balancer which created a lot more room. For sure pull the distributor so it doesn't catch on the windshield and break both. (Ask me how I know). Take your time and mark everything and you will be fine. This last time I used the plate to lift the engine from TPIS and life was a lot easier but if you are pulling it Sat., you won't have enough time to order it!
Good luck
Old Apr 8, 2009 | 06:44 AM
The Bus's Avatar
The Bus
The stock damper on the ZZ4 is to large a diameter. The ZZ4 damper will hit the crossmember frame.You'll need a smaller one.
Old Apr 8, 2009 | 06:52 AM
TJM's Avatar
TJM
THIS answer above is why this Forum is such a great tool. Ask a question and you get the answers you need.!!
To the point: I have only done this with the hood off, and it was a pleasure compared to any other car.
TJM
Old Apr 8, 2009 | 09:58 AM
rodj's Avatar
rodj
Remove the long bolt , engine mounts stay on engine.
easier if you have the hoist on the engine to take weight of bolts.may need to push them through with a screwdriver or drift
With EVERYTHING disconnected and engine connected to trans only on the locating dowels ; need to raise engine a little to clear engine mounts lugs while shaking forward to pull off bellhousing (A4 ).
There is just enough room to move engine forward to clear bellhousing before balancer hits rack.Helps if you have the front of the engine higher on the chain
Old Apr 8, 2009 | 10:30 AM
89Corvette6spdFX3
Thanks so much for all the tips. I don't have the TPIS plate but I do have an engine leveler on my hoist, which may help. Also, I do know I'll need to change the balancer and I was going to use the same one off my L98.
Old Apr 8, 2009 | 12:03 PM
steven mack's Avatar
steven mack
Remove the balancer from motor its much easier and makes more room.This is what my repair manual says to do,I did and it was much easier to remove motor.
Old Apr 8, 2009 | 07:58 PM
rodj's Avatar
rodj
Some have just "modified " the front crossmember for clearance of the ZZ4 balancer with the appropriate sized hammer.
Old Apr 8, 2009 | 09:50 PM
dclafleur's Avatar
dclafleur
I hear having some buddies over to give comments and watch helps too. Oh I guess we can turn a few wrenches as well!
Old Apr 8, 2009 | 09:55 PM
pablocruise's Avatar
pablocruise
Don't remove the hood.
Can extract the engine from the side.
May need to remove the front wheel.
Old Apr 8, 2009 | 10:39 PM
89Corvette6spdFX3
And don't forget drink some beer! haha! Glad you're coming!
Old Apr 9, 2009 | 12:37 AM
twin540's Avatar
twin540
If you have a camera take a picture of every inch . you might need it for reference later.
To Any tips on removing/installing engine?
