Fuel Pump Help Needed.
I do have an FSM someplace in a box, but since I have just moved and still unpacking boxes I haven't located it yet.
The car made the trip from Missouri to the DFW area and ran beautifully. Parked it in front of my buddies house and the next morning when I went to drive it it started and ran for maybe 15 seconds. It turns over just fine, but will not start.
Did the turn the key and there is no sound from the pump. Looked in the fuse panel and didn't see a fuse. Is is someplace besides the panel on the side of the dash? Also where is the fuel pump relay located?
I know the pump comes out the filler area and fairly sure I can figure that part out. Are there any tips I should know about before I start on this.
Thanks in advance.
Jon
The FP Fuse is located in the main fuse block assy, on bottom right near the column of breakers.
You can power the FP directly by connecting +12Vdc to ALDL pin G, lower left pin.
When you buy the FP be sure that a new filter sock is included in the box.
Use care when removing/inserting the FP assy so as to not damage the fuel level float assy.
Thanks for the help.
