88 anti-lock brakes
Old Apr 8, 2009 | 07:47 PM
Andyman11111's Avatar
Andyman11111
Default 88 anti-lock brakes
My dad just gave me his 88 c4 corvette. The anti-lock brake light on would turn on and off over the course of about a year and then it has stayed on for about the past year. He replaced the brake pads thinking that was the problem, and it did not fix. Where should i begin to inspect it and/or repair it? I am mechanically inclined and have a general knowledge of car mechanics.
Old Apr 8, 2009 | 08:32 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default brakes
The abs controls are in a compartment behind the drivers seat. Under the speaker.
Old Apr 8, 2009 | 09:43 PM
Andyman11111
Yes i already knew that. How should i go about inspecting it?
Old Apr 8, 2009 | 10:28 PM
CorvetteMike2024
Corvette Enthusiast
Default 88
Probably should consider buying a FSM. I have an 89 FSM. I will look it up in my FSM
Old Apr 8, 2009 | 10:34 PM
CorvetteMike2024
Corvette Enthusiast
Default Fsm
89 FSM 5E-4
When Anti lock malfuction occers, check: control module connector is securely connected.
Check all abs connectors
Check "brake" fuse
Check "GAGE" fuse
If prem. checks do not correct, use J 35890 ABS tester to properly diagnos.
Good luck
Old Apr 9, 2009 | 05:46 AM
86PACER's Avatar
86PACER
This is a start, but the GM Shop Manual will have detailed wiring diagrahms and step by steps checks. My ABS was a complete disaster. I fixed it using the book and a multi meter, without that special ABS tester that is almost impossible to find now.
http://www.corvettefever.com/howto/19239/index.html
Old Apr 9, 2009 | 07:21 AM
Redvette_22's Avatar
Redvette_22
What issue of Corvette Fever did this article appear in?
Old Apr 9, 2009 | 01:33 PM
86PACER's Avatar
86PACER
Don't know.
Old Apr 9, 2009 | 10:34 PM
jfb's Avatar
jfb
Call all of the GM dealers locally and see if any still have the ABS tester for C4's. Its the easiest way to diagnose your ABS.
Old Apr 10, 2009 | 08:24 AM
Andyman11111
Thanks guys. Ill try all of these things and come back here with what i come up with.
To 88 anti-lock brakes
