Smog Pump Question?
Old Jan 31, 2002 | 09:46 AM
CG77VETTE's Avatar
CG77VETTE
Default Smog Pump Question?
What exactly does the smog pump do? The bearings in mine are shot and I'm thinking of eliminating it instead of replacing it. Thanks for any help.
Old Jan 31, 2002 | 10:56 AM
Vic'89's Avatar
Vic'89
Default Re: Smog Pump Question? (CG77VETTE)
You could replace it with the air pump eliminater bracket.
I think the smog pump blows cool air into the catalyic convertor.
You will not get any codes if you remove it.
Vic
Old Jan 31, 2002 | 12:51 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The AIR pump provides air into the exhaust manifold on start up burn HCs and quickly heat the O2 sensor(s). Thereafter the diverter valve directs air into the cat(s) to help burn HCs more efficiently.
You can eliminate it but, since you are in NJ, might be worth replacing it. I just put a new one in my '86 IROC before a recent Ohio emissions test and it cost about $150 from local Chevy dealer.
Old Jan 31, 2002 | 01:11 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
I always wonder if removing the pump would shorten the life of the converter. I think it could clog up easier?
Old Jan 31, 2002 | 02:09 PM
CFI-EFI's Avatar
CFI-EFI
I never thought about the possibility of clogging the converter early. Maybe. The bearings in mine were making noise, so I took the DYI approach and started taking it a part. Long story short...I bought a rebuilt from Checker Auto parts for $29.95 exchange.
To Smog Pump Question?
