gear lube
Old Apr 9, 2009 | 07:41 PM
genoa's Avatar
genoa
8th Gear
Default gear lube
I am about to change the rear end lube in my wifes 1985. If I use synthetic, should it be 75-90--or 75-140? Also, should the limited slip additive be added to the syn. The car is only used occasionally and no hard usage.
Old Apr 9, 2009 | 07:44 PM
Aurora40's Avatar
Aurora40
I would think it should be the same weight whether it is synthetic or not. I believe GM calls for 80-w90 (people use 75w-90 because 80-w90 isn't very common apparently). What does your '85s manual say you should use?
Old Apr 9, 2009 | 09:07 PM
StealthLT4's Avatar
StealthLT4
I just changed the fluid in my D44, and used Red Line synthetic 75w90. No Posi-Trac additive needed. Working perfectly so far
To gear lube
