Flashing SYS
Old Apr 10, 2009 | 02:01 PM
Cueball90's Avatar
Cueball90
7th Gear
Default Flashing SYS
I just picked my 'vette up from installing a door ajar switch and now where my coolant temp reads on the digital display every 45 secs or so it flashes SYS for about 3 secs and then stops.
any help is appreciated!
Old Apr 10, 2009 | 02:10 PM
jrp's Avatar
jrp
One of the car's computer modules has a trouble code stored.
http://www.corvettebuyers.com/c4vettes/codes.htm
Old Apr 10, 2009 | 02:11 PM
aminnich's Avatar
aminnich
It usually just means a low battery. Maybe they had the lights on too long and it just needs to recharge.
Old Apr 10, 2009 | 02:29 PM
jrp's Avatar
jrp
I was in the middle of editing to add something like this. It's the first thing to check, since it is simple and common, but people often reply with this and fail to add that "SYS" does have some meaning.
Old Apr 10, 2009 | 03:10 PM
Cueball90's Avatar
Cueball90
7th Gear
I checked out that link but i didnt see where it talked about SYS means...
Old Apr 10, 2009 | 03:55 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Your battery is going south. It is likely that it is not charging at it's capacity.
You need a new battery
Old Apr 10, 2009 | 04:31 PM
jrp's Avatar
jrp
Sorry, "SYS" means this:
The link tells you how to find out what that code is. A factory service manual will, in turn, tell what that code means. I'd offer to look it up, but I don't have your year.
There is a similar page at that site with a some more info. I do know that they are not 100% correct for 1996, and thus maybe not for other model years either, but for both of us it should be good enough to cover most of what we need.
http://www.corvettebuyers.com/c4vettes/ecm.htm
Now... the advice to charge and check the battery is good as a first step and frequent fix, but I will say that I have had "SYS" flashing at me since I bought the car, through good batteries and bad. In my case, it is an aftermarket stereo for which the computer doesn't see a dimming circuit, and I haven't bothered to do the fix. There are a host of other things which are monitored similarly.
Old Apr 10, 2009 | 04:45 PM
Cueball90's Avatar
Cueball90
7th Gear
im pretty sure its not the battery cuz i just put a new one in like 3 years ago, and its not holding an abnormal charge or having any trouble starting
Old Apr 10, 2009 | 06:30 PM
psd_bullitt's Avatar
psd_bullitt
You can get the battery checked for free at any Autozone, ORiellys, Wallmart etc...
Depending on your driving habits and many other factors the battery may be draining more over night then the generator can charge while driving, particularly in short trips.
3 years could be a long time for some batteries... just double check to be sure before you spend $$$ at a shop for diagnostics.
Do you have an aftermarket sterio??? That is what is causing mine to flash SYS.
Old Apr 10, 2009 | 07:11 PM
Cueball90's Avatar
Cueball90
7th Gear
ok guys thanks for all the help, i got it figured out
Thanks to everyone who contributed!!
Old Apr 10, 2009 | 07:40 PM
5abivt's Avatar
5abivt
Mind telling us what it was? It's what makes forums so valuable !
Old Apr 11, 2009 | 11:40 PM
Heckler45's Avatar
Heckler45
Actually there are a few things that can cause this. Disconnecting your radio which was stated earlier will cause this. So will disconnecting yuor alrm chime for lights left on or keys in ignition. I'm pretty certain there are many other connections if left unconnected will cause this. Make sure to check all connections on any modules or switches you might have disconnected.
Old Apr 11, 2009 | 11:41 PM
Heckler45's Avatar
Heckler45
Sorry, didn't read far enough to see problem solved.
To Flashing SYS
