Warm it up?
Old Apr 11, 2009 | 09:14 PM
ambassadorgodzilla's Avatar
ambassadorgodzilla
Default Warm it up?
Awrighty, flaunting my ignorance again, but should I let my '92 LT1 warm up to operating temp before I drive it, or just let it percolate a couple minutes and drive it gently up to temp?
Old Apr 11, 2009 | 10:44 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
For over 9yrs I've just let the idle settle down, buckle up and drop her into gear...
Old Apr 12, 2009 | 01:19 AM
jfb's Avatar
jfb
Normal driving (assuming you are normal....it sounds like it) from cold is ok. NO wide open throttle 1/3 second after the engine starts!
Idling until warm is not necessary.
Old Apr 12, 2009 | 08:54 AM
Aardwolf's Avatar
Aardwolf
Unnecessary idling is bad for the engine. Drive decent till oil temps come up.
Old Apr 12, 2009 | 03:30 PM
Demonic85's Avatar
Demonic85
I will start it up, drive it, and try to keep the rpms below 2000 until I see coolant temps hit 200 and/or oil temp gauge gets a reading (150). Obviously starting it up cold and hitting WOT could cause oil starvation in vital areas of the engine leading to a spun bearing, blown head gasket, or damage to the valvetrain.
Old Apr 12, 2009 | 05:06 PM
pologreen1's Avatar
pologreen1
I let it kick down, and go.
Old Apr 12, 2009 | 07:51 PM
dan6712cc's Avatar
dan6712cc
Don't let it idle to warm up, drive normally until the pegs come off the gauges then step on it!
Old Apr 12, 2009 | 08:03 PM
StealthLT4's Avatar
StealthLT4
I drive it easy until the coolant reaches 160, but you can drive immediately.
Old Apr 12, 2009 | 08:27 PM
lt4obsesses's Avatar
lt4obsesses
I will let it idle until the coolant temp hits 100. Not so much for the warming effect, just to allow time for the oil to get where it needs to go. On cold days I will wait until the oil gets to 60-70.
Old Apr 13, 2009 | 09:58 PM
ambassadorgodzilla
I appreciate the input, an older friend of mine told me I wasn't doing it any good letting it warm up so much b4 driving it.
I now agree.
Old Apr 13, 2009 | 11:19 PM
BILLY D's Avatar
BILLY D
I've been warming up my cars and bikes for years. Never had any problems and got lots of miles form all my motors. Feels nice in the winter getting into a warm car. I figuer it this way, I don't get up in the morning and start pumping iron until I wakeup, streach and do a few warm up sets.
Old Apr 13, 2009 | 11:32 PM
NEVRL8T's Avatar
NEVRL8T
On cold days I will let my '92 warm up even though it sits in a semi warm garage.
Old Apr 14, 2009 | 12:14 PM
lt4obsesses
In the winter, when temps are below freezing, you must remeber that the oil is thick. Also the metal is more brittle. If you get on a cold engine in freezing temps, something is going to snap.
To Warm it up?
