Cloyes timing set clearance
Old Apr 12, 2009 | 10:12 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Default Cloyes timing set clearance
Do the 9-1145 and 9-3145 timing sets fit under the stock L98 timing cover? Since the description says may not fit, I want to ask. And, I don't see replacement (deeper) covers anywhere).
FYI, the two chains listed above are dbl roller chains.
gp
Old Apr 12, 2009 | 11:07 PM
ultraviolet70's Avatar
ultraviolet70
Yes they fit fine under the stock timing covers, but sometimes
http://forums.corvetteforum.com/c4-t...ease-help.html
Old Apr 13, 2009 | 02:23 AM
GREGGPENN's Avatar
GREGGPENN
Thanks Dane! Sorry I didn't notice your OP a couple of weeks ago!
Special thanks for the GMPP timing set link...maybe I'll do that instead.
BTW: After looking at your pics, I kinda wondered why the bolts for the cam retainer plate weren't a problem as well. Looks like they're REALLY close to the same distance from the center point of the cam (as the point you ground off).
gp
Old Apr 13, 2009 | 12:36 PM
ultraviolet70
Bolts aren't out quite as far as the oil boss. If I had to do it again I would go with the GMPP single roller. If you google the GM part number you'll find some decent reviews of it.
To Cloyes timing set clearance
