D36 3.73
Old Apr 13, 2009 | 08:41 AM
hardware1234's Avatar
hardware1234
4th Gear
Default D36 3.73
Looking into changing gears on a D36 from std to 3.73. Wondering what final drive rpm i'll get. When ordering gears do I also need to order the carrier.
It is a 4 spd auto c4 vette 84 model.
Cheers, Jev.
Old Apr 13, 2009 | 08:49 AM
toptechx6's Avatar
toptechx6
Some LT1 owners with the A4 find 3.73's work well, but doubt they would be a good choice with a crossfire, even too steep for the L98's due to the torque curve.
I tried the ratio in my 93 with LT1 power and found the high RPM annoying at freeway speed, I have since changed to 3.45.
I believe you will find 3.07 to be a better choice.
Old Apr 13, 2009 | 09:35 AM
rodj's Avatar
rodj
http://www.angelfire.com/fl/procrastination/rear.html
Old Apr 13, 2009 | 02:18 PM
jispr's Avatar
jispr
2500 rpm nets 73 mph with my 3.73. At least that's what the gauges said. My usual mpg is 15 - 18 if I get on the freeway. I like the 3.73 and my shift kit...closest I'll come to a race track feel.
Old Apr 13, 2009 | 03:13 PM
vette079's Avatar
vette079
If that´s correct, than there isn´t much difference with my 2.59 A4 doing 2000 rpms at 75 mph.
There is a difference, but I thought it would be more.
Anyone know of a way to calculate this for every final gear?
Or if there is a formula for this?
Old Apr 13, 2009 | 03:36 PM
blue94's Avatar
blue94
http://www.csgnetwork.com/multirpmcalc.html just have to know your tire diameter, A4 final is around .7
Old Apr 13, 2009 | 03:40 PM
Black84's Avatar
Black84
3.73's may be a bit much for a stock Crossfire. I am running 3.45's in my 84... I have been quite satisfied with the overall "feel" with this ratio. Your 84 came stock with 3.07:1 gears.
My Crossfire is basically stock except for a ported intake and .030 over bore.
Jack
Old Apr 13, 2009 | 05:49 PM
pologreen1's Avatar
pologreen1
there is a guy on DC vettes that has them in his 84 and loves them. He posted a youtube video a while ago with them, and they are nice even for that car. there are not many c4 videos with gears, I will see if I can find it, but it looks like a blast, it's playing with a ta orsomething.
Old Apr 13, 2009 | 08:35 PM
hardware1234
4th Gear
Thanks for the info so far guys. Do I need to change the carrier or can I just order a set of gears and bearings. There is bugger all info here in Australia on this. Been quoted bit over a $1000 for gears alone and $350 for carrier and $350 for bearing set.
Should have mentioned earlier, I pulled off the injection and now has a 650 vac sec, roller rockers and a good cam.
Old Apr 14, 2009 | 06:24 AM
hardware1234
4th Gear
Where can I order the gears from?
Old Apr 14, 2009 | 09:20 AM
rodj's Avatar
rodj
PM sent
Have you got 3.07's at present?
Old Apr 17, 2009 | 09:10 PM
calzonejoe's Avatar
calzonejoe
4th Gear
hi guys, no 1 said if you can put 3.73's in the 2.59 pumpkin as a straight swap? i was looking to do that swap also and wanted to know what was involved as far as keeping or replacing the carrier and how involved it is. is it something i could myself or would i have to bring it in?
thanks in advance
Old Apr 17, 2009 | 09:29 PM
JD'S WHITE 93's Avatar
JD'S WHITE 93
thanks in advance
It depends on what carrier you have now, if you have a 2.59 you can order a 3.75 rear gear from Richmond I have 100 passes on mine with no issues and NO whine.
Old Apr 20, 2009 | 10:20 AM
TJM's Avatar
TJM
Summit will sell and ship. $350 + frt.
Richmond 3:54 or 3.75 Ring and pinion.
The 3.75 will get you 107mph @ about 5200rpm in 3rd gear
3.54 about 113mph
That should about your terminal velocity in 1/4.
TJM
PS yes they fit a DANA 36
Old Apr 22, 2009 | 04:17 PM
86z51-4+3's Avatar
86z51-4+3
will the 3.75 ring and pinion fit the g44 option on an 86 ?how would that workout with a zf 6, with a stock motor?
Old Apr 22, 2009 | 05:08 PM
pologreen1's Avatar
pologreen1
you can order gears for a d36 or d44 an 86 4+3 came with D44. the trans has no effect on the gears other than , what gear ratio the trans is.
Old May 4, 2009 | 06:25 PM
hardware1234
4th Gear
Well I have been in contact with a fella who supplies gears on flea bay and was told that I can't get 3.73 gears for my 3.07 diff......is this right? Only 3.54!!
To D36 3.73
Old May 4, 2009 | 07:13 PM
toptechx6's Avatar
toptechx6
http://store.tkoperformance.com/843da36ripi2.html
Old May 4, 2009 | 11:16 PM
A95Y's Avatar
A95Y
I had to buy a ring and pinion set with a thick ring gear to go from 2:59 to 3.73. As far as durability, I stripped one of the pinion gears at the track one evening and had to drive it home. I replaced that gear and haven't had a problem as of yet. I have a D44 when I get around to it.
Old May 5, 2009 | 12:10 AM
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
I had a set of "Yukon Gears" (3.73 for 3.07 carrier, Dana 36).
So, I know they make them. Availability may be another story, though.
