Injector question???
Old Jan 31, 2002 | 10:14 PM
onry's Avatar
onry
Default Injector question???
I'm running factory LT-4 injectors and turning 397 rwhp. I beleive I should increase my injector size but I'm unsure what to go to. 24, 30 or higher? I'm thinking a set of 24s or so. Aren't the factory LT-4 injectors 22lb? As is, the car runs rich and runs well so I believe the cylinders are being supplied with enough fuel but I'm sure the stock injectors are working their tails off. I'm also only running 45lbs of fuel pressure with the stock ones. Any suggestions on what fuel pressure to use with which injectors? Thanks in advance.
Old Jan 31, 2002 | 10:22 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Injector question??? (onry)
Before I'd worried about injectors I find a way to get that 60' time down.
I run 11.50s at the MPH.
I'D Go to #30s.
Old Jan 31, 2002 | 11:19 PM
onry's Avatar
onry
Default Re: Injector question??? (mackeyred96)
The only time I've run it was on Michelin street tires at 35psi and I've also got Carerra coil overs set up for road racing on her. Not the best drag race set up. I'm still running the stock 3.45 rear end also. I'll try some #30s' and see how they do.
Old Jan 31, 2002 | 11:53 PM
GlockLT4's Avatar
GlockLT4
LT4's come with 3.5 gps (or 28#) injectors.. if you're going bigger, get 36#. LT1's come with 3.0 gps (or 24#) injectors.
[Modified by Glock'94, 5:50 AM 2/1/2002]
Old Feb 1, 2002 | 05:05 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Like to know more about your motor. 400 rwhp is about 460 at the crank. You could put the motor on a scanner and see what the injector pw is and then figure out the duty cycle. I think your probably okay for now. If you need to replace them, go to 30 lb FMS injectors. They are good for 32 lbs at the stock 45 psi fuel pressure.
Old Feb 1, 2002 | 08:45 PM
onry's Avatar
onry
Default Re: Injector question??? (AquaMetallic94LT1)
How would I calculate the duty cycle once I get the pulse width? Excactly where should I check the pulse width? Idle, WOT, part throttle? What should the duty cycle be in order for it to be in spec with my motor? Thanks
Old Feb 1, 2002 | 09:35 PM
ChrisB's Avatar
ChrisB
You should have enought injector unless you are turning over 7500 rpm or this is a blown/dry nitrous application. Actually your injector's are sized pretty much perfectly (with a little room for overhead).
Check your injector pulewidth (or duty cycle -however the scan tool reports it) at your max rpm (keep note of that rpm)
Old Feb 1, 2002 | 10:34 PM
onry's Avatar
onry
Default Re: Injector question??? (ChrisB)
Naturally asperated, and my max rpm is 7000. Although I do occasionally hit the 7200 rev limiter. :eek: My motor makes max hp at around 6800 but I usually just hit 7000 anyway.
Old Feb 2, 2002 | 04:26 PM
mackeyred96
Those RPM numbers are very close to mine.
To Injector question???
