Throttle position Sensor
Old Apr 14, 2009 | 04:45 PM
ArmyBoyATC's Avatar
ArmyBoyATC
Default Throttle position Sensor
What should my tps be set at when the car is at idle?
Old Apr 14, 2009 | 05:02 PM
pologreen1's Avatar
pologreen1
what is your car details.
the year matters most in this case, but it helps if you list in your post what vehicle you are dealing with. each years have there own settings and parts.
Old Apr 14, 2009 | 05:03 PM
Square's Avatar
Square
On my 86' I believe TPS voltage at idle is 0.54 . I would think the 85' would be the same as the engine is the same, but I cannot confirm that.
Old Apr 14, 2009 | 06:18 PM
floridamale's Avatar
floridamale
I think the range is like .47 to .63 I would have to check my FSM but .54 is what every one uses.
Old Apr 14, 2009 | 06:40 PM
cwyates4's Avatar
cwyates4
Old Apr 14, 2009 | 07:15 PM
jimmers's Avatar
jimmers
Old Apr 14, 2009 | 07:24 PM
bills1985corvette's Avatar
bills1985corvette
Setting is .54 Volts + or - .08. Spent the last week working on mine.
Old Apr 14, 2009 | 09:30 PM
ArmyBoyATC's Avatar
ArmyBoyATC
Ok thanks
To Throttle position Sensor
