Does anyone know how to input a 5v source into the pcm and log it through datamaster? It may not be possible at all but RUKWKR and I have been debating all day about a way to do it.
A source for .5 is not difficult but through the datamaster program no, using tuner pro rt (w/certain bin files), or with an emulater, yes. (someone over at third gen may have a hack for that though).
The other method is using an LM-1 and datamaster at the same time those are the only options I know. I don't use it this way, I have usually have it w/the tuning program.
Hey guys not real sure how interested you all would be in this but what about the voltage pinout? Take the voltage output on the wideband and input on either the fuel pump voltage pin or the ign volt input. At that point you could export to an excel spreadsheet and have the actual AFR in one column, the commanded in another, then just divide for percent error. Come on RUKWKR I know you want to let me try this on your car...
Rick my only question is how do you convert the voltage once its input into datamaster? Will you have to export it to a spreadsheet and do the formula to convert voltage to AFR? Thats really not that big of a deal but to be able to look over and see the actual AFR would be nice.
Sabe, it looks like this will work perfectly. Thanks rodj! He details the method in here for how to make the adjustment to the formula so the output is correct. He's coming off the A/C, I'll have to see if that is in my Painless harness.
Looks like we'll still have to export to a spreadsheet though.
Is the goal to determine the difference between the "less precise" MAF number and the "more precise" wideband number? I could see where knowing the percent error in the MAF would allow you tune based on a corrected number if you did not have access to a wideband. Just wanting to make sure Im reading in to this correctly. RUKWKR, youre my resident expert in all things fast
Are you able to export the custom engine data to a spreadsheet?
Jmoore the basic idea is to be able to see the percentage in error for the MAF. Then you simply scale the MAF table until your AFR is right on. Once it is tune properly using this method you should be able to command an AFR and in all actuality the engine would be at that AFR. This will make tuning the LT1 a lot simpler and more correct than using narrowband 02's
And 95BlueBomber is my resident expert
I'm the Luke to his Yoda
fyi his old forum name is misleading, he's the guy with the ridiculous C5 I told you about!
