what headers are the easiest to install
Tom
On my LT1, DRM 1 3/4 Long tubes are SIMPLE, but not made anymore.
Again, for an LT1 I would go TPIS then Exotic muscle, as EM are getting allot of average reviews lately with fitment.
And if you get the y-pipe they offer, header to cat-back is also a breeze.
Install note for the TPIS config, leave everything a little loose so you have some wiggle room for the header / y-pipe / cat coonections. Once all bolts have been started, tighten it up.
On the 87, I had to get the neck of the cat stretched to fit the Y pipe though.
Hopefully this fall I'll be buying a set of Melrose. I've seen some great numbers on them and have heard they're a great fit and play well with bolt-on modded engines.
Until you put some air through the exhaust, your note wont change much.
My replacment EM headers rubbed the crossmember support on the pass side and I had to cut the support back, also the EM's have only about 1/8" clearance between the #6/8 tubes and the wall on the pass side. Have to say that it concerns me and I was a bit dissapointed, there's plenty of room to tuck them in better than was done. EM's long tubes don't come with the stand offs welded on for the accessory bracket for LTx engines.
All systems have pro's and con's with them, and you will most likely have to do some amount of tweaking/wrestling with them to get your exhaust all lined up correctly. One of the mounting tabs on the Corsa was welded on backwards too, made it hard to fit in the hanger until I reshaped it. The non-working tip on the Corsa mufflers was a big "doh" for me, I already have two shiny tips, and two semi-sooty ones. It'll be pretty obvious that two are fake unless I can keep them equally clean.
My advice would be if your engine is stock, forego the header induced issues and just do a catback. (also plug access and changes were easier on the TPIS than the EM's) I'm just glad it's over with
fwiw, my engine is a nearly 12:1 compression 396, no cats and it's f'in LOUD. (EM/Corsa)
I'm just waiting for the first "noise ordinance" ticket....
i love them, you'll need an exhaust shop to put in a o2 sensor tap... i had them weld me up a complete exhaust 2.5 header back catless with dynomax mufflers... word of advice if you have them put in an o2 sensor hole DO NOT, i repeat DO NOT let them drill in your nicely coated headers... theres a flange pipe that is un coated...Kris
