Any carb experts here?
Old Apr 19, 2009 | 05:50 PM
DrEvil11417's Avatar
DrEvil11417
Default Any carb experts here?
I know there are a bunch of people running carb here..
Just putting my car together.. it was a TPI car and now i've converted to carb
I'm using an airtex carb fuel pump, 5-9psi output, holley regulator - 5 1/2 psi - and edelbrock 750cfm carb
I was previously running a TBI fuel pump from an '84 vette but it was too much for the regulator and needed a return line.. so i went with a pump made just for what i'm doing
The car will run for 5 or 10 seconds and die right away. If i try to coax it to keep running, it shoots gas out the top of the carb and sometimes a fireball
How do I get this thing to run somewhat decent?
I'm a complete newbie to carbs!
Old Apr 19, 2009 | 06:26 PM
my83432's Avatar
my83432
It sounds more like a timing problem. That's how you get a backfire out of the carb.
Old Apr 19, 2009 | 07:17 PM
84REDCROSSFIRE's Avatar
84REDCROSSFIRE
Do you have a fuel pressure gauge to make sure your pressure is staying at 5.5 psi ? Check your timing also, good luck.
Also check the float levels on that edelbrock, I have had a few Edels that came NIB w/floats out of adjustment. The little book that came w/the carb explains how to do this.
Old Apr 19, 2009 | 07:22 PM
DrEvil11417
Yeah, the floats were hanging an inch too low. That stopped the fuel from bleeding into the carb when the car isn't running... but it still dies after a few seconds
Old Apr 19, 2009 | 07:27 PM
84REDCROSSFIRE
Then Check the timming
If its not fuel, its spark then
Old Apr 19, 2009 | 07:38 PM
TWISTERUP's Avatar
TWISTERUP
If you manually hold the choke flap 2/3 to 3/4 of the way CLOSED will it run then and/or run longer ?
Old Apr 19, 2009 | 07:59 PM
Happydad's Avatar
Happydad
What I s your fuel Pressure ? Do you have a return reg? What's the Diam of your fuel lines?? This All Matters
Old Apr 19, 2009 | 09:02 PM
DrEvil11417
5 1/2 psi, no return, 3/8 id fuel lines
Old Apr 19, 2009 | 09:06 PM
TWISTERUP's Avatar
TWISTERUP
Allrighty sounds like you got it figured out.
Old Apr 19, 2009 | 09:11 PM
Churchkey's Avatar
Churchkey
It can be:
A big vacuum leak.
Timing is off.
Plug wires crossed.
Carbon track inside the distributor cap causing 2 plugs to fire at the same time.
Old Apr 20, 2009 | 09:30 AM
Demonic85's Avatar
Demonic85
Did you change the jets in the carb? If you've got a "fireball" coming out of the carb then its probably getting too much fuel.
Old Apr 20, 2009 | 04:21 PM
MR NICE's Avatar
MR NICE
on a quadra junk if the needle and seat hang up,gas will shoot out the vent,never messed with a carter.Backfire out the carb is timing or dizzy not installed correct.
To Any carb experts here?
