Dana 44 Question
Old Apr 20, 2009 | 02:18 AM
HANK AZ.'s Avatar
HANK AZ.
Default Dana 44 Question
92 LT1 with a dana 36 Do you need to change just the pumpkin to go to a dana 44 or do you need the half shafts and anything else?
Old Apr 20, 2009 | 03:27 AM
rodj's Avatar
rodj
To do a D44 dswap you need the pumpkin complete , a D44 driveshaft and a D44 C beam
All the other rear end parts interchange
The D36 DS and beam can be modified (cut down ) to suit
Old Apr 20, 2009 | 03:31 AM
WVZR-1's Avatar
WVZR-1
You need a D44 differential *complete with the cover. You'll need either a D44 drive-shaft or have yours shortened nearly 1" and you'll also need either a D44 C-beam or drill yours to accomodate the dimensions required for the D-44 install.
The balance of the rear suspension/drive remain the same. Your half-shafts will be fine.
*complete ( pumpkin & bat-wing)
rodj's fingers seemed a bit faster!
Old Apr 21, 2009 | 01:13 AM
HANK AZ.'s Avatar
HANK AZ.
Ok thanks.
To Dana 44 Question
