change oil light
Old Apr 20, 2009 | 06:53 AM
85blkrose's Avatar
85blkrose
Default change oil light
just changed the oil and need to know how to reset this thing on a 94. didnt get a manual yet.
Chris
Old Apr 20, 2009 | 07:03 AM
toptechx6's Avatar
toptechx6
Oil Change Light Shut-Off Procedure
1. Turn the key to the RUN position but don't start the engine.
2. Press the ENG MET button on the Trip Monitor. Within 5 seconds press the ENG MET button again.
3. Within 5 seconds of step 2, press and hold the GAUGES button on the Trip Monitor. The CHANGE OIL light will flash.
4. Hold the GAUGES button until the CHANGE OIL light stops flashing and goes out. This should take about 10 seconds. When the light goes out, the Engine Oil Life Monitor is reset. If it doesn't reset, turn the ignition to OFF and repeat
procedure.
Here is a link to an owners manual in PDF format courtesy of forum vendor GM Parts House.
http://www.gmpartshouse.com/download...94corvette.pdf
