Crawling under Vette ?
Old Apr 21, 2009 | 11:48 AM
86z51-4+3's Avatar
86z51-4+3
same price as pit but more usefull
Old Apr 21, 2009 | 12:10 PM
billybonesmusic's Avatar
billybonesmusic
you could always relocate your filter like i did to an easier place, and that gives you more options like 2 filters, extra sensors and stuff like that.
Old Apr 21, 2009 | 03:39 PM
flynn508's Avatar
flynn508
Originally Posted by grandspt
Thanks for all your ideas! I've been using the Rhino ramps and using two floor jacks (one on the side pinch welds) and one in the center of engine cradle. This gets the car up high enough to slide the Rhino ramps underneath. Because yes, the ramps slide when you try to drive on them! There is just about enough room to get under the car (and I'm not a very big person 174lbs 5'10.5").
By the way I like the Pit idea
Anyone use the KwikLift? It looks like a safer alternative to jackstands. Any pros or cons with KwikLift?
I dont know what kind of ramps you guys are using, mine have rubber feet on the bottom of them and they dont move at all.
Old Apr 21, 2009 | 03:59 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
Rhino ramps work fine for me.
Old Apr 21, 2009 | 04:13 PM
PGLT1's Avatar
PGLT1
You guys have it easy!! I have the Greenwood kit. Just to get a jack under my car i have to run it up on two 2x6's. Makes it a PITA to do anything under the car, but I manage..
Old Apr 21, 2009 | 04:32 PM
Demonic85's Avatar
Demonic85
For most work I just squeeze underneath the car, but for changing the oil I have to jack it up. If your old and sore, you can jack the whole front end high enough and use a low creep to roll yourself under there. Makes it a lot easier.
Old May 5, 2009 | 07:19 PM
Brute's Avatar
0Brute
Former Vendor
Little late on the discussion, but you do have options that work very well in all types of conditions.
Another Option, and you can share this with friends.
Originally Posted by rickreeves1
I don't trust the ramps. I use a jack, jack stands, and backup jack stands. You could always dig a pit in your garage floor.
Old May 5, 2009 | 07:37 PM
dry's Avatar
dry
http://www.raceramps.com/portablepitstopramp.html
This looks like a great idea!! i have been trying to figure out how to get my newly aquired C4 off the ground. My floor jack wont roll under it far enough to be able to find a solid jack point.
Old May 5, 2009 | 07:44 PM
TA's Avatar
TA
Originally Posted by jaa1992
Its probably a little less safe but here is how I change my oil:
Loosen lugs on driver side front
Jack up driver side
Remove wheel
Put oil catch pan under
Remove oil drain plug
lower car until level
Let oil drain
Jack car up
put in drain plug
move pan under oil filter
remove oil filter
Lower till level
let drain
jack back up
put on new filter
put on wheel
lower car
tourque lugs
Takes about 20 - 30 min depending on if the oil is cold or warm.
I do the wive's 04 the same way.
No jack stands?
No way I'm crawling under a car unless its on jack stands or ramps.
Old May 5, 2009 | 09:30 PM
cam355aro's Avatar
cam355aro
There are triangular spots behind the front wheels and in front of the rear wheels to jack up on. Thats where I jack mine up from and place jack stands under the crossmember and a stack of 2x6s under the wheels.
Old May 5, 2009 | 09:34 PM
ch@0s's Avatar
ch@0s
I reverse onto my ramps, set the park brake, jack the front up and put jack stands under the front.
Old May 5, 2009 | 10:20 PM
Photomania's Avatar
Photomania
I use two oak boards 3 inches thick, 12 inches wide and four feet long. I used a chainsaw to carve slots on two solid oak logs that are 2 feet in diameter. The boards fit into the slots of the logs that stand vertically about 1.5 feet high. I can't use the auto parts store ramps because my driveway is gravel. I also put bricks and concrete blocks under the boards as an extra measure of security.
Old May 5, 2009 | 10:48 PM
  #33
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Originally Posted by 95VETTEINMEMPHIS
I made me some ramps out of wood 2x6 layered gradually sloping so the front end wont hit. Made them 4 high nailed together works really great!
I did the same thing except I used 2X10's and layered them five high. I beveled the edges where the tire first rolls onto each layer so the tire rolls on them easily. They are very secure and very sturdy.
Old May 5, 2009 | 10:51 PM
  #34
jay86corvette's Avatar
jay86corvette
These are sweet! But would never pay that for them.
Old May 5, 2009 | 11:31 PM
  #35
jimg's'93's Avatar
jimg's'93
Originally Posted by 80sRule
Jacks. If it's something where I have wheel/s off, I use jackstands. If I can leave the wheels on, I have these big blocks made of 3 4x4's screwed together with several long lag bolts. They work great, and I trust them. Ramps are garbage and I wouldn't ever trust them.
You trust your car up on jacks over ramps or stands??
That's a helluva risk. any jack can (and will at some point) fail and spill it's guts dropping the car. Hope that doesn't happen, but think about it.
