Will these components work together???
Old Apr 21, 2009 | 06:30 AM
IslandVette808's Avatar
IslandVette808
Default Will these components work together???
First off, sorry for all the posts about the rockers. Just trying to get things straight since this will be my first time working on the valve train.
After spending hours online, part searching and researching, I've decided on these components and was wondering if anyone would give any feedback or suggestions on if this setup will work perfectly together:
Comp Cams 1302-16 (Pro Magnum Rocker Rollers 1.6)
Comp Cams Single Valve springs
Comp Cams Steel Retainers
Comp Cams 10 degree Valve Locks
Lunati Performance Steel Replacement Rods
Any feedback or suggestions will be greatly appreciated. Thanks.
Old Apr 21, 2009 | 09:41 AM
Muffin's Avatar
Muffin
At the risk of sounding like a smart azz, why don't you call Comp Cams and ask their tech folks. They will be in a much better position to give you the correct answer than anyone here.
Old Apr 21, 2009 | 09:47 AM
Elephanthead's Avatar
Elephanthead
You may need guide plates also, I can't comment on the compatibility with your engine without specifics, but comp cams can, they do this for a living, listen to the sage advice above.
Old Apr 21, 2009 | 10:19 AM
rodj's Avatar
rodj
Knowing what heads they are going on would help
Old Apr 21, 2009 | 03:54 PM
IslandVette808
Sorry, I guess I forgot to add some of the specifics. lol. Its an 85 L98 TPI with stock heads and cams. Here are some pics that I have of the heads. I'll try and give them a call and see what they suggest. Thanks!!
The Heads
Where the pushrods are seated
To Will these components work together???
