ring and pinion change
Old Apr 22, 2009 | 01:46 PM
86z51-4+3's Avatar
86z51-4+3
Default ring and pinion change
does anyone know if the 3.75 ring and pinion will fit in a g44 rearend .1986 early vette with iron heads.will it make the zf6 a little more improved or compliment it?guess i want to know if it is worth the hassle for quicker times at the track?
Old Apr 22, 2009 | 06:33 PM
rodj's Avatar
rodj
Getting gears to fit is no problem , whether you need them , read
http://forums.corvetteforum.com/c4-t...or-3-73-a.html
http://forums.corvetteforum.com/c4-t...to-3-55-a.html
