Poly Upper Bushings???
Old Apr 22, 2009 | 10:53 PM
Scootin_Z's Avatar
Scootin_Z
Default Poly Upper Bushings???
So i'm replacing the shocks on the C4 and the drivers upper shock bushing was shot. So all I see for a replacement after digging are the poly bushings. Are these going to go squeek squeek and drive me ????
Old Apr 23, 2009 | 12:43 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Yes they squeek after time.Or you can buy roller bearings from Guldstrand (REAL EXSPENSIVE).
Old Apr 23, 2009 | 12:54 AM
Scootin_Z's Avatar
Scootin_Z
ok....im in the dark ages...what are roller bearings from guldstrand?
Im pretty green to the C4...but the shock replacement is something I can handle...
Thanks for your post!
Old Apr 23, 2009 | 12:59 AM
Scootin_Z's Avatar
Scootin_Z
ok...I googled them. Don't see any shock bushings from them. Just a pricey coil over package (plus add another $900 for FX3...and thats what I have)
I think I will go squeek squeek...
Old Apr 23, 2009 | 01:13 AM
steve40th's Avatar
steve40th
OOps, I was thinking A Arms. Here are shock bushings.
http://qa1.thomasnet.com/viewitems/m...1001&forward=1
I am also sure summitracing or jegs has them available
Old Apr 23, 2009 | 01:29 AM
Scootin_Z's Avatar
Scootin_Z
duh...never thought of Summit or Jegs, I was just looking at the corvette parts houses.
This has the FX3 suspension, so I think the bushings are different, but not sure. Looks like they are from what I see.
Old Apr 23, 2009 | 01:55 AM
steve40th's Avatar
steve40th
Shoot, you could get some rubber from any supplier of shock bushings and make some to fit. They cant be all that hard to do.
Old Apr 23, 2009 | 11:37 PM
Scootin_Z's Avatar
Scootin_Z
so I found out there are available from GM yet...so i was told...We'll see
Old Apr 23, 2009 | 11:43 PM
stallion8797's Avatar
stallion8797
I just bought 4 new Bilsteins and the Poly kit. I was gonna replace the bushings that came with the shocks from rubber to poly. So if you want them let me know and we'll work out a price. I'll probably be installing them this weekend if the Poly kit comes in tomorrow.
Old Apr 23, 2009 | 11:48 PM
steve40th's Avatar
steve40th
If this is true, we need to know.
Old Apr 24, 2009 | 12:06 AM
Scootin_Z's Avatar
Scootin_Z
Your talking about your old rubber ones? If I can get new Rubber thats what i would like to do. There pretty cheap...but let me know what you have. And are they for the FX3 suspension because they are different than the base shock grommets
Old Apr 24, 2009 | 12:08 AM
Scootin_Z's Avatar
Scootin_Z
Yeah my Vette shop said he called and they still make them but under GM repop parts company...forgot what he called it now.
I'll post up what I find out...
If I can get the Rubber ones..thats what I want.
Old Apr 24, 2009 | 05:12 AM
dan6712cc's Avatar
dan6712cc
Depends on which bushings you get if they're going to squeak. Do not get any colored bushings like the red ones, they don't have any graphite in them. I got the energy bushings in black with graphite advertised in them and I have no squeaks, I had just about every bushing in the car replaced a few years ago.
Old Apr 24, 2009 | 09:26 AM
Radioshop's Avatar
Radioshop
Get the poly ones. Grease them with marine trailer bearing grease. You won't have a problem. Replace the lower C-arm bushing too while you're at it. On my previous 86 convertible I did a complete poly bushing swap out and after two years, never heard any squeaking.
Old Apr 24, 2009 | 11:32 AM
steve40th's Avatar
steve40th
Use this too, as this doesnt attract dirt etc.
http://www.graphitestore.com/itemDet...d=28&curPage=1
Old Apr 24, 2009 | 09:06 PM
stallion8797
I meant the new ones that come on the shocks. My Bilsteins came with all new rubber bushings on them and I'm not planning on using them. I have the FX3 as well. Am I thinking of the wrong bushings?
Old May 6, 2009 | 11:01 PM
Scootin_Z's Avatar
Scootin_Z
stallion8797....Sorry for my delay...I'm not getting my thread e mails for whatever reason. Appreciate the offer...
Where did you order the shocks from? I had my buddy get them at his cost ($175 each) from Corvette America and they were in Bilstien boxes but did not come with any bushings. Just the one under the cap for the rears, but not the insulators at that sandwich together on the top of the shock where it mounts. (fronts)
Ended up calling Bilstein and they have them in rubber. They sold me a set direct. They are rubber, so I bought 2 sets since they were cheap. The guy at Bilstein knew exactly the problem I was having with all the parts houses. All I know is the ones I was seeing everywhere online were nothing like what came off the car. The FX3 shock shaft is a different size than the stockers, so these are definitely different.
To Poly Upper Bushings???
