Moog Ball Joint Zerk Fitting Install
Old Apr 24, 2009 | 11:29 PM
LT1CORVETTE's Avatar
LT1CORVETTE
Default Moog Ball Joint Zerk Fitting Install
I know this is kind of a silly question, but is there a trick to installing them. They said self tapping bolt on the bag. I tried just screwing it in with a socket attached to a screw driver. Got maybe two threads in then stripped the threads and the zerk backed out. Do you need to tap the ball joint hole first with a tap?
Old Apr 25, 2009 | 07:33 AM
TWISTERUP's Avatar
TWISTERUP
I'd try a socket and ratchet and keep pressure on the head of the ratchet while turning--the fitting should tap its own threads--but they can be a PIA.
Old Apr 25, 2009 | 07:48 AM
redrose's Avatar
redrose
Default poor design from viking era
the zerks will 'usually' self-tap if you use heavy force and don't screw 'em in as far as you'd like ...but many will be 'angled' and some 'strip' as yours did (drill hole and use next larger zerk is repair)...i use a tap with the end ground shorter (most joints have too shallow a hole to use a 'standard issue' tap)
Old Apr 25, 2009 | 10:12 AM
Demonic85's Avatar
Demonic85
You have to align them up just right and get it started by hand, then tighten with a wrench.
To Moog Ball Joint Zerk Fitting Install
