Solid motor mounts
Old Apr 25, 2009 | 07:09 AM
jwt1603's Avatar
jwt1603
Default Solid motor mounts
Anyone know of a place to get solid motor mounts for a late C4?
Old Apr 25, 2009 | 10:35 PM
MarkBychowski's Avatar
MarkBychowski
A lot of people have been looking but as far as I know nobody makes them. I ended up fabricating my own solid mounts.
Old May 26, 2009 | 01:01 PM
Locke's Avatar
Locke
Default C-4 Solid Motor Mounts
They look pretty easy to make:
A couple of 2.5 x 2.5 pieces of .185 plate with a hole in it.
Tack a M12-1.75 X 35 bolt in the hole. That's the base.
Then weld a 3.75" long piece of 1.5" to 2.0" square or round tube to the plate. That's the upright tube.
Next, drill a 3/4" hole in the upright tube 3.1" from the bottom of the plate and weld in a 3.4" long piece of 3/4" thick wall tube. Make sure it's parallel to the base. That's the cross tube, it'll need to have a 1/2" ID. It is not centered in the upright. 1.5" goes to one side while 1.9 goes to the other.
You'll want to cut a small notch in the long arm of the cross tube, just look at the rubber mount that came out to see where it aligns the mount to the bracket on the engine.
Your local circle track builder should have everything in stock and the tools and knowledge to do it. Their normal roll bar tubing will work for the upright piece and the 3/4" cold rolled tube they use on steering shafts is the cat's meow for the cross tube.
I find it hard to believe someone isn't making them available for sale.
After we try these out, I'll post a picture.
Last edited by Locke; May 27, 2009 at 07:20 AM. Reason: Found the cross tube isn't centered in the upright!
Old May 26, 2009 | 01:31 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Are the Energy Suspension urethanes' worth looking at?
Old May 27, 2009 | 11:40 AM
Locke's Avatar
Locke
This link should take you to pictures and a drawing:
http://s606.photobucket.com/albums/t...otor%20Mounts/
Locke McCormick
North Florida Corvette Association / NCCC
Buccaneer Region, SCCA
To Solid motor mounts
