Z51 Rack Identification
Old Apr 25, 2009 | 01:26 PM
Trog's Avatar
Trog
Default Z51 Rack Identification
So... rack is shot at just under 100K miles. I'm sure the last 3 seasons of Auto-X had nothing to do with it.
None of the normal rebuilt sources have any idea and none of their books list a difference except if a C4 has 16" or 17" wheels.
I've got one coming in on Monday anyway as I need to get back together before next weekends Auto-x.
Anyone know a way to tell other than the 2.25 V. 2.75 turns lock to lock?
Thanks!
Old Apr 25, 2009 | 07:25 PM
rodj's Avatar
rodj
There is a 2 letter code stamped on the steel cover that seals the bottom of the input shaft.
I have two std racks here coded FH
Trying to find my archived info
Old Apr 25, 2009 | 07:32 PM
larryfs's Avatar
larryfs
I have a Z51 rack out of my 96, with new inner tie rod ends.
I thought the rack was bad, but it turned out to be the PS pump.
so the rack is perfect at 24000 miles.
Old Apr 27, 2009 | 01:24 AM
Trog's Avatar
Trog
looking forward to hearing what that other code is for the Z51. Larry, what is the code on your rack?
Thanks!
Old Apr 28, 2009 | 01:40 PM
Trog's Avatar
Trog
ttt.
Appears I may have lucked out & got a Z51 rack in the rebuild/swap. I installed last night & have just a fraction over 1 full turn in each direction, lock 2 lock.
There bottom cover on this rack is blank but may have been replaced in the rebuild?
Sound right on the lock 2 lock turns??
Old Apr 28, 2009 | 02:18 PM
96vetteLT4's Avatar
96vetteLT4
where did you get your Z51 rack from and how much? thanx....G
Old Apr 28, 2009 | 07:02 PM
ride250s's Avatar
ride250s
Most people get this wrong, but it is 2 turns lock to lock for a Z51 and a Z52. 2.5 turns for a base model... When I originally had mine redone, people told me all kinds of lock to lock numbers. The book says 2 turns, the parts suppliers say 2 turns, the GM techs at the chevy dealer say 2 turns, and my Z52 has 2 turns!
Make sure you test you rack when you get it... the GM dealer got the wrong one in twice, and a defective one once, glade they had to pay all the labor for their suppliers mistakes
Old Apr 28, 2009 | 08:16 PM
Trog's Avatar
Trog
Thanks for the update... Will check it again tonight for a full lock to lock count. I know when I counted from the center it sure wasn't much more than 1 full turn to lock... didn't seem like 1/4 of a turn. Maybe 1/8? But the lock is caused by the nylon bushing at each end of the rack as it hits the rack housing. Any variation in the size of that bushing will cause some change.
Rack was sourced from a local Kragen auto which carries Cardone rebuilt parts. I selected it based
on price & it comes w/ a limited lifetime warranty... Other rebuilds all were only 1 year.
Old Apr 29, 2009 | 05:54 PM
ride250s's Avatar
ride250s
Your lock to lock might go over by an 1/8th to a 1/4th of a turn, thats kinda normal. Annd just so people know, the performance rack can be used on base models without modification.
Old Apr 30, 2009 | 01:49 PM
Trog's Avatar
Trog
Bad news... new rack pukes fluid out the pinion seal like a mother.... vendor is getting me a new Delco model to replace it in the AM... Time is of the essence with an Auto-x on Sat that is a 5 hour drive.
I have pics & my service manual but can someone confirm that the high pressure line is the lower fitting on the rack. Return is higher up or closer to the steering pinion input.
thx!
Old May 2, 2009 | 03:03 AM
ride250s's Avatar
ride250s
thx!
Like I mentioned before, I had mine replaced afew times because the dealer kept getting in wrong or defective parts... What I paied was worth them doing the labor 4 or 5 times, and not me. Pluse I still have about 6 months of warranty left on the thing! F replacing the rack more than once on my own!
Old May 2, 2009 | 11:59 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
I can replace the rack on my 86 in under 3 hours. I have done it 4 times. It is just the cleanup that takes the time.
To Z51 Rack Identification
