Have questions about speedo display
Old Apr 26, 2009 | 03:50 PM
Bulldog Steve's Avatar
Bulldog Steve
Default Have questions about speedo display
Hi,
Well my display seems to freeze. It will show 55 or 13 or anything. Diff speeds when its cold or hot outside. It also goes blank. I have check the grounds that i could find. Anybody had this problem before. Thanks for your help in this matter!
Steve
Old Apr 26, 2009 | 07:09 PM
Bulldog Steve
Anybody
I am pulling my hair out and i dont have much to start with!!
Old Apr 26, 2009 | 08:09 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Needs to be rebuilt...Probably broken solder(s) or bad LCD.
Old Apr 26, 2009 | 09:32 PM
Bulldog Steve
Thanks i will check that. crazy though all the digits work !
Steve
Old Apr 26, 2009 | 09:35 PM
M.J.L.'s Avatar
M.J.L.
Digital dashes are stupid, unreliable, and look outdated IMO. The later style dashes are fine. Guess GM learned that the early style was to unreliable and expensive.
Old Apr 26, 2009 | 11:06 PM
gw962's Avatar
gw962
Originally Posted by Bulldog Steve
Hi,
Steve
Since you have a 90, the best bet is to pull the dash display. If the search works, there is a very good write up on how to do it, plus it shows the connections that are a problem.
Old Apr 27, 2009 | 08:38 PM
Bulldog Steve
Thanks for all the good help guys!
To Have questions about speedo display
