Keeps stalling :-(
Old Apr 29, 2009 | 09:57 PM
l98tpi's Avatar
l98tpi
Max G’s
Check your timing and adjust accordingly. At idle, your timing is controlled by the distributor, but when you push on the throttle, it is controlled by the ECM. Hopefully that works.
Old Apr 29, 2009 | 11:13 PM
aklim's Avatar
aklim
No it is not. The minute I connect the EST wire, the timing jumps up. When I check timing at idle, it is not at 6 deg
