Oil stabilizer?
Old Apr 28, 2009 | 07:02 PM
lt4obsesses's Avatar
lt4obsesses
Default Oil stabilizer?
Anybody use Lucas Oil Stabilizer?
LT4 w/ Hotcam. I had to go with a reman. crankshaft after bearing spun. Running Mobile 1 5w30. Is the Lucas a good idea, a bad idea?
Crank has been in for about 2K mi. Changed oil after first 500 mi. Engine runs great, sounds great. Just want to keep it that way until I can afford the proper forged steel crank. Daily driver by the way. 83K mi
Old Apr 28, 2009 | 07:46 PM
WW7's Avatar
WW7
Motors in good shape don't need additives, most additives are made to mask problems. As for Lucas Oil Stabilizer, I have seen a video showing it foaming in a motor simulation, so I personally would stay away from it. Im sure others will say they use it and its great but if it foams its not covering the metal completely and its not lubricating properly....WW
Old Apr 29, 2009 | 12:22 AM
lt4obsesses
Thanks,
I don't really believe too much in the "mechanic in can" stuff either. I'm just wondering if there is something that really adds a little protection. I was looking at the Lucas because they've been around awhile.
Old Apr 29, 2009 | 03:55 AM
85 500 horse's Avatar
85 500 horse
Originally Posted by lt4obsesses
Thanks,
So was Enron.
Old Apr 29, 2009 | 09:28 PM
96 lt-4's Avatar
96 lt-4
You don't need any extra protection.If the crank/bearings are set up properly you are fine.If they arent nothing you can pour in the motor will help it.Now if you want more protection from your motor oil switch to Royal Purple.
Old Apr 29, 2009 | 09:37 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Bobistheoilguy has a video proof of the stuff foaming up and how it does absoloutly nothing. Check it out. It's free and really interesting how it foams up.
Why royal purple? What makes it better?
Old Apr 29, 2009 | 09:38 PM
M.J.L.'s Avatar
M.J.L.
Originally Posted by 85 500 horse
So was Enron.
Old Apr 30, 2009 | 11:32 AM
lt4obsesses
So was Enron.
Good point. I'll just change a little more often, like 2500 and keep the oil fresh. The work was done by some very well qualified people, and like I said, it's running great. Thanks for the input.
Old Apr 30, 2009 | 02:10 PM
farscape1a's Avatar
farscape1a
i'm curious too. what makes Royal Purple better than Mobil 1? I thought you can't get better than Mobil 1...
Old Apr 30, 2009 | 02:53 PM
PGLT1's Avatar
PGLT1
Supposedly that new Castrol Edge is 8x better than Mobil 1. It's all a bunch of malarky!! lol
Old Apr 30, 2009 | 03:02 PM
Ryan59's Avatar
Ryan59
B&G Products MOA is suppose to be good stuff. I've wondered about adding it to my engine. Used to run B&G's extream bearing lubricant in a 600 Ninja. Cut a few 10ths off my quarter mile times and really made the transmission silky smooth.
Old Apr 30, 2009 | 08:12 PM
ChrisWhewell's Avatar
ChrisWhewell
I spent about 7 years of my corporate life as a chemist in a lab at LUBRIZOL, who makes additive packages for the vast majority of aftermarket and OEM factory fills for crankcase and transmission. Having a strong interest in engines and metallurgy prior to that time, some can imagine that I absorbed as much info as I could.
My current sentiment is that no stabilizing additive is generally necessary for most applications.
Old May 1, 2009 | 08:10 PM
86vetted's Avatar
86vetted
Just another question, how about all the hype on the boob tube about ZMAX? My DD has 200,000+ runs good but ???
Thanks,
86vetted
Old May 1, 2009 | 08:14 PM
bomar76's Avatar
bomar76
Well Zmax was sued by the FTC.....and it was shown to actually INCREASE bearing corrosion, and ZMAX was revealed as nothing more than food coloring and mineral oil in a fancy bottle.
Another snake oil that is actually HARMFUL to your engine.
Old May 1, 2009 | 08:15 PM
M.J.L.'s Avatar
M.J.L.
Thanks,
86vetted
That is ****. I don't care what anyone says. Worse than snakeoil. It should say "Engine B Gone"....The one in all engine destroryer.
Old May 1, 2009 | 08:20 PM
86vetted's Avatar
86vetted
WOW!
86vetted
Old May 3, 2009 | 12:30 PM
PGLT1's Avatar
PGLT1
Shame on you Carrol Shelby
To Oil stabilizer?
Old May 3, 2009 | 03:09 PM
bomar76's Avatar
bomar76
I have found that almost everything in a bottle or can shilled by race/motorsports legends or peddled in thinly vieled infomercials labeled as TV shows (Truck U, Two Guys Garage, Gearz, ad naseum) is total and absolute GARBAGE that does nothing beneficial (other than lining someones pockets) and is most likely detrimental to whatever drivetrain component is claimed to save/repower/extend/rebuild/lubricate/flush/coat/whatever.
Old May 3, 2009 | 03:38 PM
farscape1a's Avatar
farscape1a
that being said, what is the best oil that can be put into one of our engines? i spent a lot of money on my build and don't want to see anything happen to it. i haven't gotten it into a car yet, but it will be done in the future.
Old May 3, 2009 | 04:05 PM
bomar76's Avatar
bomar76
I am not getting involved in an oil thread other than to say I use the following:
Shell Rotella 15-40 as a break in oil and in all engines I don't use synthetic in (and as a break in oil for new engines)
Shell Rotella Synthetic 5-40 in all engines I use synthetic in.
