84 Corvette A/C Switches
Old Apr 29, 2009 | 10:15 PM
tgtexas02's Avatar
tgtexas02
Default 84 Corvette A/C Switches
On the 84 A/C systems what are the names of the switches in the system: the pressure switch on the rear of the compressor and the pressure switch (cycling?) on the line just above the orfice tube. Additionally, these compressors had another slot on the rear which can be capped off and/or is suppose to have a switch in it too? Is this for the cooling fan circuit and if so what is it called, where do you buy one, and what does it look like?
Old Apr 29, 2009 | 11:35 PM
84REDCROSSFIRE's Avatar
84REDCROSSFIRE
Try here
http://www.autozone.com/autozone/cat...entId=cat10018
And here
http://www.autozone.com/autozone/cat...m%40169b0a3%5D
Old Apr 29, 2009 | 11:38 PM
84REDCROSSFIRE
More here
http://www.autozone.com/autozone/cat...entId=cat10009
GOOD LUCK
Old Apr 30, 2009 | 12:12 AM
tgtexas02's Avatar
tgtexas02
Thank you very much. The cooling fan switch (compressor mounted) is exactaly what I have been trying to locate. Not a single parts house has had any idea as to what I was talking about. In fact, two different places have sold me a pressure cut-out switch which looks very similiar with two wire leads--I knew better but I bought them anyway! All is well now.
To 84 Corvette A/C Switches
