TTS Datamaster authorization codes gone?
Old Apr 30, 2009 | 01:44 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default TTS Datamaster authorization codes gone?
I was helping someone out with TTS and went to hook mine up to start to record and it said mine was not registered etc. I bought this years ago, and Andrew Mattei has helped reregister it etc. My disk is useless now, but I am curious if yo have had the authorization code just dissapear. The one andrew gave me, I keep on my computer is wrong, even though it worked for a long time.
Do, updates cause it to change codes?
ANyways, just curious
Old Apr 30, 2009 | 09:41 PM
rodj's Avatar
rodj
I recall in the past when people have had to rebuild or have bought a new laptop that Datamaster would not recognise their code when they reinstalled Datamaster.
Then they had a major problem getting TTS to isuse a new code , even with proof of purchase because TTS claimed the code should still work
Old May 1, 2009 | 12:48 AM
steve40th's Avatar
steve40th
I got a new authorization code, now I am getting a runtime error.
"tts datamaster runtime error 2147221498 8004006 over flow"
I have uninstalled and reinstalled several times. Something is amiss
Old May 14, 2009 | 09:50 AM
mseven's Avatar
mseven
yep, everytime I reformated in the past using the same set-up disc, same IP etc. it would not recognize the pc. I believe the software has a "bot of somesort in it to keep it from being hacked. Their claim that it will recognize a previous pc is BS, although Vickie has been quick to get me another code (3 times). If they spent as much time on the program as they did making it hacker proof it would be nice.
After a fresh windows instal and all additional software is loaded I clone the entire c/drive (laptop) to a seperate hard drive which pretty much ends all the TTS nonsense.
Old Aug 19, 2009 | 11:41 PM
1BAD88's Avatar
1BAD88
Has anyone tried to virtualize the machine that will run TTS?
Will it run on Windows CE?
That way you could back up the image and use the back up if your hardware failed.
To TTS Datamaster authorization codes gone?
