interior lights flicker
Old Apr 30, 2009 | 06:35 PM
rjhcorvette's Avatar
rjhcorvette
Default interior lights flicker
Hi, I have a '93 LT1 and I've been noticing that when I have either the running lights or headlights on my interior lights flicker. It only does this however on the backlights of the crystal displays (speedo, a/c, and radio). I am figuring there is a loose ground somewhere. Is there a common ground wire for all three displays? Thanks.
Old May 1, 2009 | 12:27 AM
jfb's Avatar
jfb
Engine running and lights flickering, unplug the alternator and if the lights stop flickering, you have a voltage regulator in the alternator that is oscillating. You can replace the voltage regulator.
Old May 1, 2009 | 06:50 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
check the ground in the kick panels -- driver side above speaker and passenger side same place...
Two more to check is block near oil filter and driver side bell housing..
To interior lights flicker
