Acceptable shifter "rise"???
Old May 1, 2009 | 02:47 PM
daytonaer's Avatar
daytonaer
Default Acceptable shifter "rise"???
Background;
I put in a new clutch, flywheel, PP, master and slave over the winter and am getting ready for summer.
No I did not get the c-beam "plates."
I noticed the shifter rise up about 1/4" under load AFTER I started paying attention to it, because off all the threads I have read on here about it. So today I got under the car and re-torqued the c-beam bolts. 40 foot pounds on the transmission and 60 on the diff. They were not loose at all and pretty much already torqued (I used blue loctite on assembly).
I did not pay attention to the shifter during heavy acceleration before and am unsure if it always did this.
The "glue" stuff that was on the c-beam is pretty much gone but there are not chips left that would prevent the beam from sitting flush. That's about all I can think of that is different.
I did not inspect the motor mounts all that closely, other than they are there and connected.
I'm starting to get paranoid about this as the autocross season starts this weekend!
I have also read a thread stating there will always be some shifter rise, does about 1/4" sound about like the norm?
Thanks,
Mike
Old May 1, 2009 | 03:59 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Could be the C-beam plates
Could also be you now noticing shot engine mounts.
Old May 1, 2009 | 04:17 PM
95BlueBomber's Avatar
95BlueBomber
1/4" doesnt sound too bad to me. There shouldn't be much movement at all there. Did you replace the C beam bolts or re-use the stockers?
Old May 1, 2009 | 05:46 PM
daytonaer's Avatar
daytonaer
It doesn't seem that bad, it may just be climbing up on old motor mounts. The engine rocks a little, not what I would consider bad however.
I re-used the stock bolts.
The rear suspension bushings, although not in new shape, are all there. The differential is not moving around.
I just am unsure if I am noticing a problem or just noticing something that's always been there.
Old May 1, 2009 | 06:17 PM
95BlueBomber
I would recommend starting with either c beam plates or at least new bolts from GM. The threads stretch and when re-used you will never really get the right amount of grab on them.
Old May 2, 2009 | 09:56 PM
daytonaer's Avatar
daytonaer
Well I beat the snot out of the car today at a SOLO school. And nothing developed. So I'm probably fine, but I will look into buying new bolts although I can almost guarantee my dealer will say "can't help you" even if I show up with a valid G.M. part number...
As for c-beam plates, yeah they sure are nice, but I have a metal band saw, drill press and welder. I can't justify his price for them, although they sure are nice.
To Acceptable shifter "rise"???
