C4 auto overdrive gear ratio
Feb 3, 2002 | 04:50 PM
NCM Ambassador
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VII Veteran
St. Jude Donor '04-'05-'08-'09-'10-'13-'14
C4 auto overdrive gear ratio///rear gear/rpm formula
What is the gear ratio for a 1993 A4 overdrive gear. I think it is .67 but am not sure.
[Modified by Crusher137, 6:04 PM 2/3/2002]
Feb 3, 2002 | 05:02 PM
Re: C4 auto overdrive gear ratio (Crusher137)
Close. 30 % overdrive. The gear ratio is .70:1
Re: C4 auto overdrive gear ratio (CFI-EFI)
yep i agree, i believe it is .7
Feb 3, 2002 | 05:03 PM
overdrive is .70 to 1
Feb 3, 2002 | 05:20 PM
NCM Ambassador
Cruise-In V Veteran
Re: C4 auto overdrive gear ratio (93Zeus)
Thanks, I have the formula from DTS to figure out your RPM's with certain rear gears and needed the trans overdrive ratio to do it. Want to move up from the 3:07 but don't want to tach crazy numbers in overdrive at cruising speeds.
Crusher
Feb 3, 2002 | 05:27 PM
NCM Ambassador
Cruise-In V Veteran
In case anyone wanted the formula...
Q. How can I determine what ratio to use for my application?
A. mph x gear ratio x trans ratio x 336 ÷ Tire Diameter = RPM
Tire Diameter
Example:
70 mph x 3.73 (gear ratio) x .70 (trans ratio) x 336 ÷ 27(tire diameter) = 2274RPM
70 mph with a 3.73 ring and pinion over drive transmission in 4th gear with a 27" tire will perform at 2274 RPM...
[Modified by Crusher137, 4:29 PM 2/3/2002]
[Modified by Crusher137, 6:07 PM 2/3/2002]
Feb 3, 2002 | 08:15 PM
NCM Ambassador
Cruise-In V Veteran
TTT
Feb 4, 2002 | 10:17 AM
70mph??? Who goes that slow?? :D :jester
