WeatherStrip Question
Old May 3, 2009 | 05:49 PM
Binski's Avatar
Binski
Default WeatherStrip Question
I am finishing up the weatherstrip on my 93 LT1. The weatherstrip around the front windshield has a couple of plastic pins inserted to hold the weatherstrip in place. Do those just pry out???? Are they reusable???? New pins did not come with the new weatherstrip from Wilcox. Thanks.
Old May 3, 2009 | 05:52 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
They pry right out, use a knife or small screw driver on each side and you can reuse them if you are careful pulling them out.
Old May 3, 2009 | 06:04 PM
tim32920's Avatar
tim32920
I used small needle nose pliers and reused mine.
Old May 3, 2009 | 07:28 PM
Binski's Avatar
Binski
Thanks again.
Old May 3, 2009 | 09:23 PM
pianoguy's Avatar
pianoguy
The special tool to remove them is like a wide screwdriver with a curved blade with a split in the middle.
Old May 4, 2009 | 05:07 PM
tim32920's Avatar
tim32920
you just described my ex wife!
To WeatherStrip Question
