Is there a difference between the 90-96 version and the 84-89 version. Mine broke(the pivot) exiting turn 11 at Thunderhill raceway; promptly got stuck at wide open throttle going down the staightaway.
i'm no expert, but that is a really bad thing! isn't the throttle body supposed to snap shut because of the spring? or did something get jammed?
It jammed under the brake pedal, I turned the ignition off and coasted into the pits, the tach needle got jammed on the right hand side of the gauge, 500 RPMs beyond redline. I drove it home after my friend did a "Mcgiver" fix on it, it seemed ok despite the overrev.
I bought RD RACING's gas pedal mount to keep things from braking. I dont see it on their site anymore, but if you email them they may have it. It was billet aluminum for the bracket that brakes, such as yours. http://www.r-dracing.com/
