weatherstripping - glue or not glue?
Old 05-05-2009, 11:36 PM
Stingraynut
Stingraynut's Avatar
Default weatherstripping - glue or not glue?
I've read a lot of forum posts over the years about glueing on the weatherstripping, but when I spoke to a spraypainter today he asked me why I'd want to glue it on - it made me think.
Perhaps not all the bits of weatherstrip need glueing?
I had planned to glue it all, to help guarantee against leaks, but when I thought about it, one side of the strip isn't glued, so why should the other?
The painter suggested that if it needed to be glued in certain areas, to use dabs of superglue to hold it in place.
What do other members think?
Old 05-05-2009, 11:41 PM
Binski
Binski's Avatar
I have been using regular 3M black glue made for weatherstrip. I would rather take this extra step, spend a few bucks more and be sure I don't have to redo. This has worked well for me.
Old 05-06-2009, 12:12 AM
grinditout
grinditout's Avatar
It needs to be glued to be water tight, get all body work out of the way; then glue it down with 3M weatherstrip adhesive.
Old 05-06-2009, 12:16 AM
96GS#007
96GS#007's Avatar
Received 1,792 Likes on 1,078 Posts
Depends on what piece of weatherstripping. Some pieces need to be glued, others do not.
Old 05-06-2009, 12:18 AM
slickfx3
slickfx3's Avatar
My Hatch strip peeled off and I cleaned under it, I doesn't need glue on the bottom what else?
Old 05-06-2009, 02:57 AM
Stingraynut
96GS - aha, thats what I was wondering - which bits DO need glue and which don't?
grinditout - I sort of agree with you, but the weather-stripping is not glued to both sides, otherwise we couldn't open the door etc - so it makes me wonder if one side is waterproff without glue, why not both?
Old 05-06-2009, 05:14 AM
65Z01
65Z01's Avatar
Cruise-In II Veteran
If you mean the strip that runs around the hatch opening and against which the hatch glass seals, my OEM WS had a yellow slipery substance under it so I used lithium grease when installing the new WS.
For one thing the adhesive keeps the WS in position and prevents it from "moving around" when a moving part contacts it. Plus the OEM WS was frimly glued down and that's good enough for me.
Old 05-06-2009, 06:35 AM
pianoguy
pianoguy's Avatar
I replaced my A and B pillar weatherstripping and didn't glue it - no problems so far.
Old 05-06-2009, 07:12 AM
PAINTER MAN
PAINTER MAN's Avatar
I agree. I replace these two areas on my car 6 years ago. No glue and no leaks. I did clean the channel very well.
Old 05-06-2009, 08:39 AM
pianoguy
pianoguy's Avatar
Ditto - I took a lot of time getting the channels clean. The new stuff fits in there quite snugly.
Old 05-06-2009, 10:18 AM
Steve59
Steve59's Avatar
I just did the hatch ws on my 87 coupe. When I removed the old ws, there was very little glue and that was only in the corners. I used a Wilcox replacement ws. I had not centered it correctly under the third eye and had to remove it and re-install it. That's when I realized that there is grease of some type inside that ws to help seal it. I assume that that grease would also prevent any glue from sealing that area.
Old 05-06-2009, 10:55 AM
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Few members did not use glue and they are satisfied with their work. I have the entire kit for my CE LT4 and I will not use glue.
Old 05-06-2009, 02:42 PM
skybolt31
skybolt31's Avatar
On my 86, I did the A pillar without glue and am going to do the 95 A&B pillars and have no intention of using glue. Lots of people glue and have no issues and lots of people don't glue and have no issues. In all of the WS posts that I have read, I have never seen one where someone says that they didn't glue and it leaked, they went back and glued and it fixed it. So the choice is yours, but gluing is not necessary, at leas on the A&B pillars.
mjlorenson (12-19-2022)
Old 05-06-2009, 06:36 PM
Stingraynut
Wow, some interesting replies here.
Until yesterday I had not considered the idea of not glueing, now I am.
Old 05-10-2009, 07:15 PM
Stingraynut
OK I am going to follow the advice of the paintshop and not glue except for any obvious corners.
The guy at the paintshop also says he uses supa glue to hold the W/S in places where it won't stay - sounds like a good idea. he says then if the W/s need removing it's easier, and I have read posts where the W/S has not been put on right and needed to be moved.
I live in the tropics and during the wet season (Jan-April) we can get up to 4" of rain an HOUR!! That will be a good test. I'll post back with the results .
Old 05-10-2009, 10:23 PM
tim32920
tim32920's Avatar
I redone all the weatherstripping on my 92 and I only put 3m glue on it and only on the corners and NONE of it leaks.I read through alot of posts on here before I started and I suggest you do the same,it will help you alot.
Old 05-10-2009, 11:28 PM
PLRX
PLRX's Avatar
2017 C4 of Year
No Glue
To weatherstripping - glue or not glue?
Old 05-11-2009, 08:28 AM
PGLT1
PGLT1's Avatar
I did my hatch WS last fall. I left it in the rain with a paper towel in the corners to check. Bone dry after two days!! So my take is no glue unless needed.
Old 05-11-2009, 09:10 AM
pitchadude
pitchadude's Avatar
What about car shows? How will it effect judging?
Old 05-11-2009, 09:19 AM
flynn508
flynn508's Avatar
I will soon be redoing all my weatherstrip on my 86. I figured that the pressure of the doors, glass, etc. on the strip when its closed up would keep things dry. I also assume that the strip needs some 'breathing room' to expand and contract in the heat/cold and if it was glued in wouldn't that cause it to split or break?
Quick Reply: weatherstripping - glue or not glue?
