I usually just change the entire blade,dont touch the wiper arm at all.The blade with the metal just pops off the wiper arm with a screwdriver.No need to take the wiper arm off.If you cant get it off or dont know how,some of the parts stores will do it for you.
I know the C4 needs a lower profile design than some other replacements offer.Youll have to check in the parts stores which seems to be the lowest fitting profile that wont hit the hood.
Yeah I think I'm going to Autozone and have one of those imbiciles touch my car after spending $15,000 on the engine and such.
I'm not new to wrenching, I just can't figure this one out, the rubber does not slide out itr is crimped on, perhaps I can uncrimp it, but there got to be a better way and that is the post.
You must use the low profile style to clear under the hood. I have been using the ANCO AeroAdvantage for a couple years and they work great with no clearance issues.
From: Formerly from the Great White North but now residing in the Desert Southwest NM (The Land of Dis-Enchantment?)
Originally Posted by onedef92
Trico Exact Fit or Anco AeroAdvantage Low-Profile. You can get them at AutoZone, Wally World, or Pep Boys and they'll fit with no issues whatsoever.
Interesting...I tried the Anco and they rubbed the hood edge. The Trico Exact Fit 20-2 are exact replacement units. CarQwest sells them as their part number 20-52
What does spending 15,000 bucks on your engine and such have to do with the wiper blades and letting the "imbeciles" change it for you?
Some of those guys do this ALL DAY LONG.I was just being helpful since I did not know your skills from your post,but your elitist reply made me shake my head here.
I bet the Imbeciles at Autozone would run circles around you in a wiper blade changing contest.
Nevermind sorry, you meant well, Thanks for the help
I bought Trico Exact fit for 7.99 ea, they worked.
