Coolant Smell through ACC
Old Feb 4, 2002 | 01:10 PM
White Lightning's Avatar
White Lightning
Default Coolant Smell through ACC
My 89 L98 has a 180 degree thermostat. When the water temp goes above 180, a slight smell of coolant starts coming through the automatic climate control system. I've checked my exhaust for coolant smell, but nothing. I've checked the coolant level in the radiator and the overflow tank, but no change. I haven't noticed any coolant leaking from the car to the ground.
Sometimes the ACC lights and digital display go wacky, flickering and flashing, so I'm thinking there's a slight leak somewhere that's messing with the circuitry.
Any ideas of the possible problem?
Thanks in advance,
-WL
Old Feb 4, 2002 | 02:07 PM
art91's Avatar
art91
Default Re: Coolant Smell through ACC (White Lightning)
I don't know if this is the same problem, but when that happened to me last summer, it was my heater core. At first I just smelled coolant, then it started fogging the windows. I hope it isn't your heater core, because it's expensive to fix, and a bear to do yourself.
Good luck.
Old Feb 4, 2002 | 02:24 PM
maduraj's Avatar
maduraj
Default Re: Coolant Smell through ACC (art91)
oh oh. That's not good. Mine is doing the same thing. No leaks or anything. But I do smell some coolant when the temperature get up there :eek:
Old Feb 8, 2002 | 10:14 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Same here. I have the new core waiting to install but I'm really not looking forward to doing it... Try feeling the carpet under the dash near the heater core, it's probably wet.
Old Feb 8, 2002 | 01:00 PM
SunCr's Avatar
SunCr
Your Display problems maybe a bad ground or the Cluster could be on its way south. For '89, there is a Cluster ground that passes through the Firewall with the ECM Harness which is near the Heater Core. There is a second ground in the driver's footwell. Might be good idea to have a radiator shop pressure check your system to pinpoint a possible leak. Since you only notice it when the thermostat opens, maybe something closer to the fresh air inlet, such as a manifold gasket, as opposed to the Heater Core.
Old Feb 8, 2002 | 01:38 PM
vader86's Avatar
vader86
Default Re: Coolant Smell through ACC (SunCr)
sounds kinda like a heater core problem
Old Feb 8, 2002 | 02:06 PM
jwg2's Avatar
jwg2
Hey, don't be afraid to do your heater core yourself. I did mine. It took a good ten hours, but everything pretty much went as described in the service manual, and I don't think I scraped a single knuckle.
Old Feb 8, 2002 | 10:14 PM
The Dingo's Avatar
The Dingo
Default Re: Coolant Smell through ACC (jwg2)
Gee, ten hours working under the dash of a C4 - I can hardly wait to start that project...:rolleyes: :rolleyes: :rolleyes: :)
Old Feb 9, 2002 | 11:07 AM
KLLRVET's Avatar
KLLRVET
Default Re: Coolant Smell through ACC (Red 90 L98 Coupe)
Replacing the heater core SUX!
Tony
To Coolant Smell through ACC
